Dead K Series
Re: Dead K Series
Post by mwmackenzie » Wed Oct 26, 2016 2:06 pm
Scuffers wrote:
mwmackenzie wrote:
Scuffers wrote:
Craig said there is a bit of piston missing from a camera inspection :oops: My guess is that's what closed the plug? Gutted as it was running so well up until then!
missed that, yes, very possible...
if that is the case, you have to look at different root cause, piston breakup has limited causes.
Scuffers, the cause was clearly luck, bad luck at that lol.. The fact that I own the car is enough for all sorts to go wrong.. mystical stuff like the cam crank bending and herring bone sticking can cause punctures all due to the car being in my cursed care.. If you look though my posts you'll see I'm not the luckiest chap on here :lol:
Re: Dead K Series
Post by mwmackenzie » Wed Oct 26, 2016 2:09 pm
Shug wrote:
istoo wrote:my 111s behaved near the same. coils fixed it for a bit but then it came back.. replaced the Throttle Position Sensor and its been brand new ever since.
edit... touchwood
Coil pack and TPS fixed a cracked piston? Good skills :damnfunny :mrgreen:
I think he may have read my FB post stating issues and suspected coil pack failure, that's what I thought it was until Craig found a closed plug and stuck a camera down it :oops:
Re: Dead K Series
Post by Shug » Wed Oct 26, 2016 3:24 pm
mwmackenzie wrote:
edit... touchwood
Yeah - I'm joking. Hence multiple smilies :thumbsup
istoo
Re: Dead K Series
Post by istoo » Wed Oct 26, 2016 7:48 pm
edit... touchwood
Not my skills, CMC diagnosed and fixed it.
S2 111s
istoo
Re: Dead K Series
Post by istoo » Thu Oct 27, 2016 10:10 am
mwmackenzie, following this with close attention, I have K series paranoia... I often thought about buying a MGF TF for spare engine, what options are available to you at this point in time.
S2 111s
captain
Re: Dead K Series
Post by captain » Thu Oct 27, 2016 11:49 am
DVA a standard k-series... cams, headwork, big valves, ITB's. 180-ish bhp, original fitment, cheaper than a honda...
Re: Dead K Series
Post by mwmackenzie » Thu Oct 27, 2016 2:12 pm
captain wrote:DVA a standard k-series... cams, headwork, big valves, ITB's. 180-ish bhp, original fitment, cheaper than a honda...
The above is a substantial outlay... My preferred option is 160VVC engine, 270 exhaust cam, off set dowells in VVC cams, a KMaps remap, 4-2-1 manifold, de-cat, Larinni back box and a lightweight flywheel on my CR box. That should make for a lively little bugger.... but budget is what's killing me as our 320d spat out all it's oil yesterday too :( time will only tell where it all leads :thumbsup
Re: Dead K Series
Post by mwmackenzie » Thu Oct 27, 2016 2:20 pm
istoo wrote:mwmackenzie, following this with close attention, I have K series paranoia... I often thought about buying a MGF TF for spare engine, what options are available to you at this point in time.
At this moment I have just got standard options which would be very reliable, DDtB is looking to see if he has and salvageable goodies, I'm hunting down a 160 engine but not finding any reasonably priced will also need an S2 111s ECU and engine loom to make it plug and play... was offered a new '150 mile' engine for £2K which I'll not be taking, simply can't afford it and Iain Leslie has very kindly offered me his engine at a decent price too! Very unsure what to do I know what I want to do but it's not the sensible option... sensible would be reliable though... aaaarrrrrgggghhhh! :scratch
hilow
Re: Dead K Series
Post by hilow » Thu Oct 27, 2016 6:06 pm
Put it to bed for the winter and save up or have a christmas wish list or sell.
hiscot
Re: Dead K Series
Post by hiscot » Fri Oct 28, 2016 7:54 am
tut wrote:Good car for a young lassie though especially at that price.
Clare had one and really liked it.
We have had a few , think cheap roadster not sportscar and they are not that bad
bob
hiscot
Re: Dead K Series
Post by hiscot » Fri Oct 28, 2016 7:58 am
Don't rule out the 135 , plenty about ! And they go well enough IMO
bob
Re: Dead K Series
Post by Dominic » Fri Oct 28, 2016 9:05 am
Most 135s have nearer to 145 bhp..... not sure if all 160s achieved as much as 160...
Re: Dead K Series
Post by Shug » Fri Oct 28, 2016 9:28 am
Yep, but Marks' talking about MG TF160 VVCs, which aren't anything to do with the Lotus sport 160s.
The VVC in the back of the old Shugmobile dynoed at 189bhp (after I sold it) with a good exhaust and TBs and some very light port matching (the engine hadn't been opened), so the VVCs give good power and a good spread. I'd have another one, rather than a big valved ported standard K - which may have given a slightly higher peak, but nowhere near the spread of usable power.
Re: Dead K Series
Post by Dominic » Fri Oct 28, 2016 10:14 am
istoo
Re: Dead K Series
Post by istoo » Sat Oct 29, 2016 7:55 pm
What production cars came with the VVC?
MGF TF, S2 111s, inseem t think there was a Rover/MG 25 shape that had that engine with a. Red grille...
I.e. How many VVC engines are likely to be still kicking about?
S2 111s
