Locking wheel nut tool
Post by simon » Thu Nov 09, 2006 11:25 am
tuscan_thunder wrote:Maybe PM Silu82 (can't remember his name) too? He's in ABZ and has an S2 Exige
All S2s have the same locking nuts as standard so there's bound to be someone here with the same one. G, I can bring my jack with me if you're worried Ronnie will be busy. I don't think it will be a problem, it says in the info pack from John that they will help change pads (but may be a small charge).
Post by Andy G » Thu Nov 09, 2006 11:28 am
check under the battery casing! Thats where mine was and I had taken the boot to bits twice!
The pad that is likely to be most worn is the inside one also. You may be okay though for KH, depends how harsh you are on the brakes.
Might be worth coming along just so you can try all the differentl locking wheel nut tools likely to be there, as MMC aren't much use in these situations, although they did hunt high and low when I thought I may have left mine there :oops: :oops: :oops:
Post by Andy G » Thu Nov 09, 2006 11:29 am
Gareth wrote:Not going to take the risk.
Ronnie may need his jack for someone else and I don't want to risk loosing out on track time.
If I can't get hold of one by tomorrow I'll give KH a miss.
I'm taking my jack anyway to try and give the massive Q for tyre changing at the end a miss!
I've never had the brake warning come on in mine when the pads needed done.......
Post by Gareth » Thu Nov 09, 2006 11:33 am
Cheers Andy, above the battery is the only place I haven't looked - didn't know it existed. That's where Robin suggested.
Post by ed » Thu Nov 09, 2006 11:51 am
ed wrote: have you removed your battery cover etc and had a good hunt for your one.
:roll:
Post by Gareth » Thu Nov 09, 2006 11:53 am
:roll:
I know I know :oops:
Post by Gareth » Thu Nov 09, 2006 12:52 pm
Hurrah...found it!
Boot is bloomin soaking tho. The wee pouch which was in the batery covers is soaked. Drying off with all the boot linings on the radiator. :(
Post by Andy G » Thu Nov 09, 2006 12:54 pm
Gareth wrote:Hurrah...found it!
:thumbsup :thumbsup
Good man! Have you get a set of pagids ready to go :wink:
Post by Gareth » Thu Nov 09, 2006 1:05 pm
Pagids sitting waiting... :D
Post by alicrozier » Thu Nov 09, 2006 1:29 pm
Gareth wrote:Drying off with all the boot linings on the radiator. :(
Is that not a clam off job... ;)
Give me a shout if you need a hand, you've fitted rear pads before right?
http://www.elise-faq.info/content/brakes/padchange.php
Post by Gareth » Thu Nov 09, 2006 1:37 pm
Yeah, once before. Should be OK**
G
**Ali switches off mobile :D
