albutch
by albutch » Fri Jul 27, 2007 1:00 pm
I'd top up with water and see if it holds the level. You can get the coolant tested for specific gravity to make sure its not too dilute (unlikely unless you are topping up regularly.
mj9
by mj9 » Fri Jul 27, 2007 1:19 pm
right i just went out to check the car at lunch and i had very little coolant in the tank - topped it up with water and the car is fine!!! phewwwww (i had been cr*pping it all morning!)
Getting some coolant first thing!
By the way i noticed if the coolant is low, the car might not idle properly - not sure if someone else has experienced this?
VW Golf black (company car)
BMW 320D M Sport Coupe black (gone)
VW Passat (company car)
gone
Lotus Elise S2 111s lazer blue (gone)
BMW 3 series new shape black (gone)
Nissan Skyline GTT-R34 black (gone)
graeme
by graeme » Fri Jul 27, 2007 1:24 pm
by Rich H » Fri Jul 27, 2007 1:26 pm
Coolant level shopuld not affect idle, just temp (Until it siezes that is)
by GregR » Fri Jul 27, 2007 1:27 pm
coolant schmoolant. My car's been running on about 3 litres of Knockhill's finest bog water for the past month
by Rich H » Fri Jul 27, 2007 1:27 pm
*BANG*
- Jedi Master
by robin » Fri Jul 27, 2007 5:09 pm
The mixture of coolant and water is not there to promote cooling (indeed it does the opposite) it's there to reduce corrosion and to prevent freezing (not an issue this month anyway). The longer you run it with stream water in it, the more corrosion there will be - it's worth flushing out the swamp weeds and replacing with proper premixed coolant (or buy 5L of neat coolant and dilute to 50/50 with tap water). It's not like it's expensive or anything ...
- Jedi Master
RICHARDHUMBLE wrote:Coolant level shopuld not affect idle, just temp (Until it siezes that is)
Quite. HGF on the other hand ...
by Rich H » Fri Jul 27, 2007 5:10 pm
Didn't say it was good!!
mj9
by mj9 » Sat Jul 28, 2007 9:46 pm
HGF - this word should be banned!
gone
