John Reid wrote:It doesnt do any harm going to the bigger size when you consider how much cheaper you can pick one up for..
Think mine is a "polished out" 56mm from a rover turbo, or tomcat or whatever.
Noops has one the same, much better than the std plastic one in anyones book. Much cheaper than a 52mm one from Elise parts..
It *DOES* harm to step out;
(a) it slows airflow
(b) it causes turbulence.
Ideally you want to sleeve the new TB to have the same I/D as the plenum, though a compromise will be to blend the two together over an inch or so in each direction, or get a smaller TB.
Can you not just take a 48mm alloy body, remove the butteryfly and spindle, bore it out, source/make a brass disc of suitable OD to replace the smaller one you took out?
If so, I'll happily pay someone with skillz and access to supplies to get mine reworked.
