Lots of torque.. brakes are very progressive.mwmackenzie wrote:All coming together Victor and looking great in the pics mate... Best of luck and i'll be keen to try following you round KH hehehehehe![]()
When do you hope to have her finished and final spec released? How does she feel with the new Kiwi Rog head, brakes etc??
Mark
Victors Mutterings part 1
- Victor Meldrew
Re: Victors Mutterings part 1
You will need both seats in for A8 IIRC
- Victor Meldrew
Yep.. second seat was removed to ferry tyres up to Tut's.. I have to cut some harness holes into it yet before I refit it. Sector 111 gromet kit from MRSA.Mikie711 wrote:You will need both seats in for A8 IIRC
What size Kumho's are you running?
If your home I might give you a phone.
you have PM
- Victor Meldrew
Anyone any good with a dremel..?
I need to cut the holes in the pax seat to fit the seatbelt grommets from sector 111.
I seem to remember on the RLC we used an angle grinder.
- Victor Meldrew
robin wrote:I seem to remember on the RLC we used an angle grinder.
Not a good combination.
- Victor Meldrew
Close enough..NOOPS 160 wrote:True..., however there will be a( holes in everything closetut wrote:Not a good combination.
tut) definitive answer..
Shocks are due delivery on the 9th.. so fitting and ride setting will be some time shortly after that.
- Victor Meldrew
Yes, the shocks will go on the day they arrive, and I will set the ride height to what I have it just now so as not to mess up the geo too much. Probably followed with a good long road run to play a bit with the damper setting to get a feel for what it does.
I have someone lined up to fit the rear links and do the final geo a week or so after that, to give the springs a chance to settle in a bit. (although that probably shouldnt be needed with the Eibach upgrade but you never know)
Tyres have to be fitted on spare wheels, (they have arrived) but the TPMS system has not been delivered yet. Still need to work out how that will be mounted and powered.
The pads will probably go on after the sticky tyres are fitted. Apparently they squeal like a stuck pig on the road and only quieten down after they warm up a bit
should not be a major concern for me then...
Victor Meldrew wrote:Yes, the shocks will go on the day they arrive, and I will set the ride height to what I have it just now so as not to mess up the geo too much. Probably followed with a good long road run to play a bit with the damper setting to get a feel for what it does.
The pads will probably go on after the sticky tyres are fitted. Apparently they squeal like a stuck pig on the road and only quieten down after they warm up a bitshould not be a major concern for me then...
Mine never settled much after fitting.
The TPMS thingy has got a 7 year battery. See the features bit http://www.hofmannsofhenley.co.uk/conte ... .asp?id=34 so no need to power it. I was going to go for one but decided I've spent enough cash on the car just now.
1999 S1 Elise - For Sale
2003 E46 M3 - Sold
2003 E46 M3 - Sold
- Victor Meldrew
ABZ-Elise wrote:Victor Meldrew wrote:Yes, the shocks will go on the day they arrive, and I will set the ride height to what I have it just now so as not to mess up the geo too much. Probably followed with a good long road run to play a bit with the damper setting to get a feel for what it does.
- Victor Meldrew
