It's back but now misfiring (Was: Won't start)
Re: Won't start - name this noise (video included)
Post by robin » Sat Apr 20, 2013 3:38 pm
Some say he can do a head gasket in the dark ... we just know he's called Woody :-)
Post by tut » Sat Apr 20, 2013 5:21 pm
woody would not need to do it in the dark, he has a fantastic torch to use, and that has certainly lit up at least one tunnel in its day.
<BG>
Post by BiggestNizzy » Sat Apr 20, 2013 9:39 pm
Mod's, can we get a like button ?
Post by robin » Sun Apr 21, 2013 1:35 am
BiggestNizzy wrote:Mod's, can we get a like button ?
You'll find that on facebook :-)
Post by woody » Mon Apr 22, 2013 11:35 am
*Bows* Thanks all. 25 minutes to remove the head last time. :lol: Torch was provided for me yesterday.
Had a look at Puffin's car yesterday & I'm none the wiser. Fuel pump primes and on the first crank after standing there was a pop, but no other hint of combustion. After cranking it a few more times, there was no hum of fuel from the car as you'd usually have.
I didn't have any tools, so couldn't pull the plugs. I had donkey's ODB2, but of course there was no where to plug it. Car has the EFI tech box of tricks in the boot I think are sometimes found in VVC S1's and can cause issues?
Plug leads definatly need replaced either whatever else happens as at least one was had the plastic breaking up quite badly.
sendmyusername
Post by sendmyusername » Mon Apr 22, 2013 11:48 am
Have you tried bypassing the immobiliser just in case it's that ?
Only need the plug and two wires ?
I'm not sure how the imobiliser works on these cars, whether it stops the fuel pump, or the stops the spark ?
s29ttc
Post by s29ttc » Mon Apr 22, 2013 12:53 pm
woody wrote:*Bows* Thanks all. 25 minutes to remove the head last time. :lol: Torch was provided for me yesterday.
Woody isn't this just the misfire detection unit. Sure there is someway of bypassing it to make sure that isn't the issue?
1999 S1 Elise 111S - Fun Spec
Post by robin » Mon Apr 22, 2013 7:38 pm
sendmyusername wrote:Have you tried bypassing the immobiliser just in case it's that ?
You cannot bypass the spark inhibit part of the immobiliser. This does sound a bit like that - fires once then dies. I've seen this before with a broken code wire from Lucas 5AS unit to MEMS1.9 (I'm guessing it's similar on MEMS2J as used by S1 VVC).
The box of tricks is the misfire detection unit I would think. I think it just plugged into the original loom so could be unplugged and original loom plugged back together ... I've never actually done this though, so apologies if wrong.
However, I would still start with the spark plug leads/bores.
s29ttc
Post by s29ttc » Mon Apr 22, 2013 8:06 pm
Robin,
I think your exactly right. As above I thought this was a misfire detection unit. I do believe the had to be made so they could be retrofitted as required so it would make sense. I'm sure we where fault finding on my car right at the very start which is believe it or not about 5 years ago it Ali bypassed it to eliminate it.
I wouldn't believe this would stop it firing up, more an issue running. I bet new leads and possibly spark plugs will sort it!
sendmyusername
Post by sendmyusername » Tue Apr 23, 2013 5:07 am
Removed under advicement
Last edited by sendmyusername on Tue Apr 23, 2013 10:27 am, edited 2 times in total.
Post by robin » Tue Apr 23, 2013 8:09 am
"sendmyusername" Your car is an S2 an the ECU does not contain a code lock. The S1 MEMS1.9 and MEMS2J ECUs do contain a code lock, in addition to the fuel/crank immobiliser that's common to both cars.
Post by woody » Tue Apr 23, 2013 8:40 am
robin wrote:"sendmyusername" Your car is an S2 an the ECU does not contain a code lock. The S1 MEMS1.9 and MEMS2J ECUs do contain a code lock, in addition to the fuel/crank immobiliser that's common to both cars.
His is an S1 now, just hasn't updated his profile pic.
Post by robin » Tue Apr 23, 2013 8:43 am
OK, then the immobiliser can only be bypassed by also changing the ECU to e.g. Emerald or sending it away to have the code lock removed ...
puffin
Post by puffin » Fri May 03, 2013 5:52 pm
Update
Kirk who used to work at MMC took a look at it today and it has spark and it's not the immobiliser so the next guess is something compression related :(
Does anyone have a compression tester in the glasgow area and a free hour?
Bad girls don't drive Micras
Post by Dominic » Sat May 04, 2013 9:26 am
I might have a compression tester... Will have a look in the garage.
