5th gear, long legs.
Re: 5th gear, long legs.
PH4 TF
Thread drift...
GTFYB (Billy Connolly code) with the codes......
You Shell guys obviously get paid toooooo much....
Now where has Kinger gone......At his age probably still recvering from the Frolic drive home....
mxvx. Apologies re the run home Sunday. Meant to leave with you but got waylaid....then we passed on the back road etc. Next time....
S2 Blue Exige guys and I do not work at Shell....
M
 M
Mini Cooper (wife spec)
BMW dog wagon
BMW dog wagon
Martin,martins wrote:Thread drift...
M
Not been at Shell for a few year now, and yip.... Still recovering from Frolic.
See you next Saturday.
Can vouch for a removable wheel kit ! I'm 6ft7 (and a bit of a chunk )  so it really helps ! The removable kit from demon tweeks worked well for me and was miles cheaper than other places.  It gives about 40 mm space and getting in and out much easier.
Sent from my HTC One_M8 using Tapatalk
B&C S1 Elise
I have had the elise for years and never noticed this as being a problem - until this thread, then driving the car at the weekend, and noticing that I have a gear stick / knee interface issue..... thanks for bringing this to my attention
Ta, does that kit re-use the oem wheel?Muzzaa72 wrote:Can vouch for a removable wheel kit ! I'm 6ft7 (and a bit of a chunk ) so it really helps ! The removable kit from demon tweeks worked well for me and was miles cheaper than other places. It gives about 40 mm space and getting in and out much easier.
CMC K20 S1
Blog https://www.blatters.com/car/1746
That's ultimately why I didn't go removable because you need a Momo or similar steering wheel to fit the boss kit. The standard wheel doesn't fit, I really like the standard one hence why I went for just a 40mm spacer. (which also had to be adapted slightly to fitcaptain wrote:Ta, does that kit re-use the oem wheel?Muzzaa72 wrote:Can vouch for a removable wheel kit ! I'm 6ft7 (and a bit of a chunk ) so it really helps ! The removable kit from demon tweeks worked well for me and was miles cheaper than other places. It gives about 40 mm space and getting in and out much easier.
This is what mine looks like with the spacer.
Oh Ye mine came with the momo lotus  wheel , not sure if that was because the car is a   bell and colvill 140 or whether someone has swapped it out over the years .... Sorry about that
B&C S1 Elise
