Pauline's finally buying...need your help guys :)
Re: Pauline's finally buying...need your help guys :)
Post by mckeann » Fri Feb 25, 2011 11:49 pm
campbell wrote:Don't build him up Pauline, he'll need a tranquiliser shot if you keep going like this!!
29...please tell me you are not just 29 at the mo...sheesh, I am OLD.
I'm 29 too, Grandad :wink:
Post by campbell » Fri Feb 25, 2011 11:54 pm
Aye, there are 2 diffs.
1) She's better looking than you.
2) You weren't looking after my interests nearly 10 years ago when you were, er. barely 20
:shock:
Fluoxetine
Post by Fluoxetine » Sat Feb 26, 2011 8:14 am
robin wrote:.
Orrrr, if you can get to the car with the engine stone cold, don't let it warm up on the idle - instead get it on the road straight away, put it too high a gear for the road speed (say 4th or 5th at 20mph) and go full throttle for a second or two. The car won't accelerate much, if at all, but if it's piston slap the noise will become more pronounced, whereas the clack clack from the tappets won't change much if at all when you do this.
iirc, this is also a good method to check if the clutch is slipping. :mrgreen:
Post by tut » Sat Feb 26, 2011 9:49 am
Pauline, did you see this 111S on SELOC?
http://forums.seloc.org/classified.php? ... d&id=19042
