New toy
- mwmackenzie
Re: New car at last! :) Understeer!!!!
Check SELOC techwiki for geo settings, they have the std and motorsport settings on there, I'm using the 340R settings on my Elise... Hope you get it sorted soon mate! I'm not a fan of adjustable suspension from the point of view that I know jack about setting a car u and Lotus know lots so I'm happy to use what they design so I run S2 LSS on mine athough I feel they are maybe a tad softly sprung for the track but a great allround set up, height adjustable only.
Was just looking up info on Seloc Mark. You running road or track 340R settings? What are others running?mwmackenzie wrote:Check SELOC techwiki for geo settings, they have the std and motorsport settings on there, I'm using the 340R settings on my Elise... Hope you get it sorted soon mate! I'm not a fan of adjustable suspension from the point of view that I know jack about setting a car u and Lotus know lots so I'm happy to use what they design so I run S2 LSS on mine athough I feel they are maybe a tad softly sprung for the track but a great allround set up, height adjustable only.
http://wiki.seloc.org/a/Geo_Setups
Mckeann expect a call
(that's why I think Mike will do fine, that and his lack of imagination).![]()
Mike,
I have all the gear for measuring camber and toe at my place (pre measured/cut poles and string that attach to the car), its a piece of piss to do, so your welcome to fire round sometime and see what you have as a base measurement. Its relatively easy to alter it aswell, if you can be arsed
We really need to see where the car is just now before we go changing anything. It may be geo, it may be dampers, or it may be driver. I wouldnt discount anything at the moment, but its best to start with geo as its free, then driver as its also free (although can be more difficult to adjust than the geo
) then dampers as a last resort.
I do think you need to try it on a dry track too. My old S1 on standard dampers was oversteery when dry, understeery when wet. My S2 on LSS is the opposite. No idea why.
happy to help matey, let me know.
- mwmackenzie
I think it's the road settings as my front camber is not that bad... you can have a drive when i get it back mate..
Mark
Mark
its not impossible to drive in steel toe caps, infact, i had a very memorable pax lap from FD back in the old days when he was in hillwalking boots and he can pedal like a madmanscib4 wrote:Will leave my steelies at home from now on
Mine was setup as 340 road .... works for me...scib4 wrote:Was just looking up info on Seloc Mark. You running road or track 340R settings? What are others running?mwmackenzie wrote:Check SELOC techwiki for geo settings, they have the std and motorsport settings on there, I'm using the 340R settings on my Elise... Hope you get it sorted soon mate! I'm not a fan of adjustable suspension from the point of view that I know jack about setting a car u and Lotus know lots so I'm happy to use what they design so I run S2 LSS on mine athough I feel they are maybe a tad softly sprung for the track but a great allround set up, height adjustable only.
Just to add, its pretty neutral in the dry, well on road anyway.mckeann wrote:
I dont think you can compare road and track. My S2 is very neutral on road, but does understeer on a dry track. Not as bad as it was mind, and hopefully an upcoming change of dampers will sort it completly. I just dont think you can go mental enough on the road to get the same problems.
Sounds just like what you said about my driving style and I managed to get oversteermckeann wrote:Your driving stylee needs a few subtle tweaks for the elise. I.E turning in, and stomping on the throttle wont give you oversteer, it'll cause understeer![]()
Exige V6
neil wrote:Sounds just like what you said about my driving style and I managed to get oversteermckeann wrote:Your driving stylee needs a few subtle tweaks for the elise. I.E turning in, and stomping on the throttle wont give you oversteer, it'll cause understeer![]()
thats different from turning in, getting sideways THEN stomping on the throttle. That'll cause oversteer
mckeann wrote:neil wrote:Sounds just like what you said about my driving style and I managed to get oversteermckeann wrote:Your driving stylee needs a few subtle tweaks for the elise. I.E turning in, and stomping on the throttle wont give you oversteer, it'll cause understeer![]()
Exige V6
go and see Willie at CLCM.
He's set up the RLC and the Mule, and neither understeer
Will second Andy. Although perhaps take details of the "standard" settings you want, Willie will set it up just as you tell him. Or as you don't
Although I guess he has "std" Lotus settings in his books as he does all of MMC's setups.
i usually get minbe as close to 340r settings as it will go
