Where for a new K series
GilesM
Re: Where for a new K series
Post by GilesM » Mon Feb 27, 2012 5:45 pm
Rich H wrote:Deroure are great for parts, not always the cheapest but pretty close for OE parts.
Ordered loads for the Esprit from them mostly because of the linked parts catalogue.
Customer service is pretty good too.
Thanks, a few good reports always give me a better feeling before I part with real cash.
GilesM
Post by GilesM » Mon Feb 27, 2012 5:48 pm
campbell wrote:Pentland Land Rover have provided me with some useful standard bits, as have Pentland Components (no relation!) in Sighthill (branches elsewhere too).
PLR have moved from base at Craiglockhart to the "motor village" or whatever it's called, at Newbridge off M8 / M9 underpass junc.
Thanks Campbell, could be interesting, I'll have a wee look, the good point is I'm in no rush for the bits, the car will be off the road for as long as it takes.
GilesM
Post by GilesM » Wed Feb 29, 2012 12:35 pm
Can anyone help here, these two are on the PTP website, the MLS Elise gasket is Multi Layer Steel and the MLS Landrover gasket is Multi Layer Shimmied, they both seem to be improvements on the original, but are they the sam thing, just different names, or even typo, would they be good for the standard K Series re-build, any thoughts would be apprciated.
Thanks
Giles
http://www.ptp-ltd.co.uk/shop/8_139/lot ... gasket.htm
http://www.ptp-ltd.co.uk/shop/365_167/l ... _exige.htm
Post by campbell » Wed Feb 29, 2012 12:54 pm
It is often said that the original is just fine.
I've had two of them.
The first one didn't fail.
The second one hasn't so far...
Post by woody » Wed Feb 29, 2012 12:56 pm
GilesM wrote:Can anyone help here, these two are on the PTP website, the MLS Elise gasket is Multi Layer Steel and the MLS Landrover gasket is Multi Layer Shimmied, they both seem to be improvements on the original, but are they the sam thing, just different names, or even typo, would they be good for the standard K Series re-build, any thoughts would be apprciated.
Thanks
Giles
I believe they're the same thing and share the same Payne part number if OE spec.
Various schools of thought on which gasket is best, but I'll be using an MLS when I rebuilt mine soon. I've always just picked mine up at PartCo, who were a good bit cheaper for the full, OE spec, kit.
Post by campbell » Wed Feb 29, 2012 12:58 pm
I should add. It is also often said that the more important aspect is to ensure you are using the metal dowels provided with the gasket. IIRC...
Post by woody » Wed Feb 29, 2012 1:03 pm
campbell wrote:I should add. It is also often said that the more important aspect is to ensure you are using the metal dowels provided with the gasket. IIRC...
This, and of course ensure that the liners protrude enough.
On that note, who are able to supply new liners? I thought DVA sold them, but cannot see them listed?
GilesM
Post by GilesM » Wed Feb 29, 2012 1:33 pm
The liners standing pround will be sorted, Deroure still list the liners on their website:
http://www.deroure.com/?gclid=CJKnioufh ... zAodCAIUzA
GilesM
Post by GilesM » Wed Feb 29, 2012 1:34 pm
woody wrote:I believe they're the same thing and share the same Payne part number if OE spec.
Thanks
KingK_series
Post by KingK_series » Mon Mar 05, 2012 11:48 am
Thanks
Giles
Beware there are masses of cheap chinese non OE spec parts for K out there now
DO NOT WORRY ABOUT RETAIL OUTLET, OR ELISE/SHIMMED FITMENT, THE ONLY THING THAT IS IMPORTANT IS THAT PAYENNE IS WRITTEN ON THE PACKAGING, anything else is rubbish.
MLS works with proper standproud, but will leak until the engine has seen 2/3 heat cycles, and the coatings have cured, old elastomer needs 4 thou standproud but is more tolerant [ie next failure will take longer] if you do not deck the block. All engines with either gasket need the 82deg PRT,
however these are just sticking plasters.......the solution to HGF is the above plus proper water pump and significant changes to water flow management in the block. aka K series thread
Post by woody » Mon Mar 05, 2012 12:12 pm
Well, decked my block last night, should have 7 thou standproud.... initial checks suggest I do, and evenly, but it was past midnight and my vernier height stick isn't the best, so have a bit more checking to do.
From what I remember reading, Goateaz (sp?) manufactured liners are OE?
I know you intend it to be in the other thread, but if you don't mind, what pump do you reccomend (I see Eliseparts do a pump that looks better?) and are there any mods to the block I can do at this point, save for closing the deck and all that entails (though I do see you are pointing down that road as the ultimate HGF fix).
Thanks.
KingK_series
Post by KingK_series » Mon Mar 05, 2012 1:03 pm
woody wrote:Well, decked my block last night, should have 7 thou standproud.... initial checks suggest I do, and evenly, but it was past midnight and my vernier height stick isn't the best, so have a bit more checking to do.
Thanks.
7 though will bind the cams in the head
deck to 4 thou only, - get Stu to help out
Goetze are the parent company to Payen, but the right gaskets, elastomer or MLS all have Payen written on them or come in an OE Landrover box
There is no commercially available effective water pump.....
Post by mac » Mon Mar 05, 2012 9:51 pm
What about an electric water pump?
KingK_series
Post by KingK_series » Mon Mar 05, 2012 10:49 pm
mac wrote:What about an electric water pump?
they don't pump enough pressure...... full stop.
GilesM
Post by GilesM » Thu Mar 15, 2012 1:13 pm
Before I start taking too many bits off the car, I have a quick question, would people recommend draining the oil before I start, and would it be a good idea to use any cleaning agent in the oil before I drain it, my concern is that I would need to run the engine up to temperature and then drain the oil, and it would stay hot with no new oil added, should I worry about this, obviously I don't intend to run the engine with no oil in it, or would it be better to just drain out what ever will drip out from a cold engine.
Thanks
Giles
