111R rebuild
Re: 111R rebuild
Post by Mikie711 » Fri Aug 24, 2012 9:23 am
I only work on the car during the day, when she is at work ............ usually :D
The install of the supercharger and intercooler will be the same as it is on a 2 eleven. A 2elevens engine cover is flat and as far as I can tell the height of the rear clams are approx the same between the elise and the 2 eleven. As long as neither the intercooler or the supercharger don't protrude above the height of the engine rocker cover, which they don't, and that the grill openings in the engine cover don't drop down to far then it will all fit.
If for some unforeseen reason that it doesn't fit then it will be the engine cover that it will affect not the clam as the cut out in the clam for the engine bay is wide enough to clear the engine. In that case there will have to be a rethink regarding the engine cover and I'll cross that bridge if and when I get to it.
But it is a very valid point which I have wondered about myself, no way to know for sure until the end when the clam is fitted, as with any thing like this there is always an element of suck it and see :D
Re: 111R rebuild
Post by Shug » Fri Aug 24, 2012 9:36 am
Re: 111R rebuild
Post by campbell » Sat Aug 25, 2012 10:20 am
With the right collective brains and Mike's boundless talent, I imagine a revised engine cover will be a...er...doddle :-)
Why are you asking Iain...got a project of your own in mind?!
Re: 111R rebuild
Post by Mikie711 » Fri Aug 31, 2012 6:15 pm
Post 1 updated.
C7Steve
Re: 111R rebuild
Post by C7Steve » Fri Aug 31, 2012 6:32 pm
Car taking shape nicely.
What kind of supercharger is that, is it the same one, that's used in the Exige, and 211, or are they all different?
Nice thread :thumbsup
Steve.
Re: 111R rebuild
Post by tut » Fri Aug 31, 2012 6:37 pm
Eaton M62, the same as on my Honda.
C7Steve
Re: 111R rebuild
Post by C7Steve » Fri Aug 31, 2012 6:46 pm
tut wrote:Eaton M62, the same as on my Honda.
Tut, is it the same supercharger that is used on the Exige S, Exige cup, Exige V6, Evora S, and the 211?
Sorry for my ignorance :oops:
Steve.
neil
Re: 111R rebuild
Post by neil » Fri Aug 31, 2012 7:00 pm
Looking good Mike :thumbsup
Exige V6
Re: 111R rebuild
Post by Dominic » Fri Aug 31, 2012 7:21 pm
Looking good. :thumbsup
Re: 111R rebuild
Post by Mikie711 » Fri Aug 31, 2012 9:05 pm
Cheers guys, things are coming together even if it is taking longer than I expected.
Steve, M62 charger is used on the Exige S2's and 2-11. The new Exige, like the Evora uses a different charger and not sure about the new Elise S.
Re: 111R rebuild
Post by tut » Fri Aug 31, 2012 11:53 pm
Steve.
I did not think it was the same one Steve until Mike told me that was the one that he was fitting to his car.
However I do not know about the rest of the range, Mike can answer that.
Re: 111R rebuild
Post by Mikie711 » Sat Sep 01, 2012 12:17 am
OK here goes,
Elise (2zz-GE) SC uses a Eaton M42 non intercooled.
Exige S, 2-11 260 cup cars and my Elise use an intercooled Eaton M62.
Evora S and the new V6 Exige use a non intercooled or charge cooled Harrop HTV1320 supercharger.
The New Elise S uses a 2ZR-FE engine and a Magnuson R900 Supercharger water charge cooled.
C7Steve
Re: 111R rebuild
Post by C7Steve » Sat Sep 01, 2012 7:43 am
Mikie711 wrote:OK here goes,
Mike,
Thanks for that :thumbsup
Steve.
Re: 111R rebuild
Post by Mikie711 » Sat Sep 01, 2012 10:41 pm
Some progress but not as much as I hoped.
Post one updated.
Re: 111R rebuild
Post by tut » Sun Sep 02, 2012 3:36 am
Bit of a bugger about the manifold Mike.
As regards drilling, it looks as if a couple of the holes overlap so would this cause a problem, or could you fill the originals?
