Matelotman
by Matelotman » Sun Sep 09, 2007 9:06 pm
I found the reason behind my wobbly/banging exhaust - on one of my heavier landings, I've hit the flexi through the hole - this has jarred the exhaust back and resulted in the mount and retaining bolt being sheared off (I can't imagine that this is a standard method of exhaust mounting but does anyone know of a bracket that fits this?) I've fabricated a semi permanent one anyway so no rush if there's not one
Flexi
Where's the mount?
Stu160
by Stu160 » Mon Sep 10, 2007 1:44 am
Best bet would be MMC?
Stu
- Jedi Master
by robin » Mon Sep 10, 2007 7:49 am
Yes, there is a Lotus special part that bolts onto the cat flange and has a post to go through the exhaust rubber. Costs about £1 from Lotus - I bought 10 once upon a time because loads of cars are missing them - but I cannot find them
by Rich H » Mon Sep 10, 2007 7:58 am
Quality effort though, that must have been some landing!!
Matelotman
by Matelotman » Mon Sep 10, 2007 8:26 am
Could have been one of many landings.... cheers Robin, I'll get onto Lotus but I've made a makeshift bracket that should be ok in the mean time.
- Barefoot Ninja
by tut » Mon Sep 10, 2007 10:45 pm
Chris told me that when he fitted his Gaz shocks, he guessed at ride height settings, and ended up with 60mm at the rear.
That has to be some sort of Elise record.
Matelotman
by Matelotman » Tue Sep 11, 2007 1:07 am
So imagine the height of the rear panel/diffuser
Now all sorted at 120mm at rear
Matelotman
by Matelotman » Tue Sep 11, 2007 11:59 am
robin wrote:Yes, there is a Lotus special part that bolts onto the cat flange and has a post to go through the exhaust rubber. Costs about £1 from Lotus - I bought 10 once upon a time because loads of cars are missing them - but I cannot find them
I got in touch with Murray's - £16.11 inc vat, (nearly £1)
by alicrozier » Tue Sep 11, 2007 12:20 pm
tut wrote:Chris told me that when he fitted his Gaz shocks, he guessed at ride height settings, and ended up with 60mm at the rear.
Not what you need over the jumps.
Remember Scotty's old S1 when he did the 'Finnish Rally' stylee flight heading south from Glenshee? Resulted in wheels through the clam and bent wishbones.
I braked heavily after seeing him take off and it was still the biggest jump I've ever had! Rounded the next corner to see him trundling along with a comical wheel wobble...
