PROVISIONALLY SOLD !!!!!!
I have just bought an Xbox360 steering wheel so don't need the following anymore. ALL of the below works 100% as is in as new condition
I dont post in here often but dont let that put you off as John Stewart, Kenny, Ed, Tut, Big D and a few others know me well.
- PlayStation 2 c/w power & scart cable
- Spare PS2 controller (original)
- Logitech Driving Force Pro Steering Wheel
- Original Games x 8
The Steering wheel is compatible with PC games too (USB port) e/g GTR2 and Rfactor
Will try and punt them here before they go to Ebay.
Pictures
I am based in Aberdeen so local collection / delivery prefered ( but postage possible at cost to buyer)
Ideally, I shall not be splitting..........
The wheel is worth £70 on it's own
The complete lot for £100 Prefer payment by Paypal
Thanks
Cal
Fits Sony PS2
Force Feedback
Get ready to experience the most realistic steering wheel ever made. With 900 degrees of wheel rotation, the Logitech® Driving Force Pro duplicates the true to life steering dynamics of cars like never before on your PlayStation®2 computer entertainment system. And for games that don´t support 900 degree steering, the wheel automatically switches to standard 200-degree mode. Add in state-of-the-art Force Feedback technology, and you have the most advanced, most authentic driving experience in gaming. The advanced rack and pinion steering system lets you turn through 2-1/2 steering wheel rotations. The rubber wheel, sequential stick shifter, and responsive gas and brake pedals all combine for an incredible level of performance. Get behind the Driving Force Pro and get as close to reality as possible... no seatbelts required.
Full rubber wheel with 900 degrees of rotation
Grab the comfortable grip and turn the wheel 2-1/2 times from lock to lock, just like in a real car. Available in supported games only.
Automatic 200 Degree Steering compatibility mode
Automatically restricts the rotation of the wheel to 200 degrees of rotation in games that do not support 900 degrees of wheel rotation.
Force feedback technology
Feel the road, bumps, gravel, walls, and other effects in games. Logitech's latest force feedback technology delivers greater realism compared to previous force feedback products.
Solid construction with precision engineering
Steel bearings support the main shaft to provide smooth, accurate steering with minimal lateral movement. And an optical sensing system encodes all steering movement with digital precision.
Two wheel-mounted paddles and sequential stick shifter
Shift gears up or down conveniently with easy-to-access shifters. Or use the paddles as L1 and R1 buttons and the shifter as L3 and R3 buttons.
All the control you need
The 8-way D-Pad and four PlayStation® action buttons (circle, square, X, triangle) give you convenient control of menu selections, view changes, car control functions, and other standard directional pad controls in driving games. Four secondary action buttons (L2, L3, R2, R3) act as L2, L3, R2, and R3 buttons of standard PlayStation®2 controller to be used for a variety of car control functions such as horn, lights, and wipers. Select and start buttons are also conveniently located on the wheel front.
Dual clamping system
For optimum control, you need the wheel tightly locked down on your desk or table. The dual clamping system keeps the wheel base secure, but it's also easy to tighten and loosen for quick installation and removal.
Gas and brake pedals mounted on textured no-slip floorboard
The pedals add to the realism and precision of your driving experience. And the exclusive carpet grip system features special teeth to prevent the base from sliding around. The system retracts for use on hardwood or other smooth floors.
Easy installation and setup
The USB port connection makes for easy plug-and-play operation. And status indicator lights tell you when wheel is powered up and calibrated, and also when the wheel is in 200 or 900 Degree Steering mode.
