TommyK
by TommyK » Fri Jul 25, 2008 7:47 pm
What is the best way to preserve a battery when not used for extended periods (normally 4 weeks)?
Disconnect or trickle charger?
Thanks
Performance through tight pants.
- Barefoot Ninja
by tut » Fri Jul 25, 2008 8:10 pm
I would use a good trickle charger, ie a C-TEK.
by campbell » Sat Jul 26, 2008 12:38 am
I have a Halfords trickle charger and it does the job jus' fine. Usually only plug in over the winter.
- Jedi Master
by robin » Sat Jul 26, 2008 9:46 am
Disconnect it at the -ve terminal. It'll need a proper charge after about 1 year of not using it, so 4-weeks at a time is no bother. Remember to disarm the alarm just before you disconnect the -ve terminal.
TommyK
by TommyK » Sat Jul 26, 2008 11:58 am
Thanks guys - much obliged.
Tommy
