(NLC) My Polo....
Paolo
(NLC) My Polo....
Post by Paolo » Fri Sep 05, 2008 7:27 pm
...is b*ggered. Came out tonight and the front has dropped a fair amount at the passenger side.
Obviously suspension related but what exactly is it? and is it fixable without spending too much?? Any ideas??
Or suggestions about where I could take it near paisley??
Paul :thumbsup
Re: (NLC) My Polo....
Post by jj » Fri Sep 05, 2008 7:35 pm
I`ll give you a replacement polo for £2500. I`ll even let you keep your broken one.
Paolo
Post by Paolo » Fri Sep 05, 2008 7:40 pm
jj wrote:I`ll give you a replacement polo for £2500. I`ll even let you keep your broken one.
If you accidently put the dot in the wrong place JJ and actually meant 25.00 - I'll take it! :mrgreen:
Fooking brilliant - why do these things always happen at the most awkward of times??
neil
Post by neil » Fri Sep 05, 2008 11:15 pm
sounds like a broken spring. jack it up and take a look - should be pretty obvious if it is
Exige V6
tenkfeet
Post by tenkfeet » Fri Sep 05, 2008 11:28 pm
Never knew there wassuch a SE Polo massive . I have a 1.4 SE :lol:
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Paolo
Post by Paolo » Sat Sep 06, 2008 7:59 am
Polo MASSIV!!
Yep, looks like a broken spring....
Expensive?? and do you think I'll be able to drive it for a few miles (to get to a garage??)
Matelotman
Post by Matelotman » Sat Sep 06, 2008 8:11 am
A spring should only be about £35 - http://www.gsfcarparts.com/
not too difficult to replace (easy to say if you know what you're doing and have spring compressors) as for driving it.............
Paolo
Post by Paolo » Sat Sep 06, 2008 8:52 am
Matelotman wrote:A spring should only be about £35 - http://www.gsfcarparts.com/
Thanks. Is that a no-no to drive??
Post by Rich H » Sat Sep 06, 2008 8:57 am
Depends on if its still supporting the car, if it is then just consider it "slammed" chopping springs is a common way of lowering cars. If its busted in the middle then it'll be on the bumpstops (If there are any left) that is not good.
Paolo
Post by Paolo » Sat Sep 06, 2008 8:59 am
Rich H wrote:Depends on if its still supporting the car, if it is then just consider it "slammed" chopping springs is a common way of lowering cars. If its busted in the middle then it'll be on the bumpstops (If there are any left) that is not good.
Fook. Thanks.
neil
Post by neil » Sat Sep 06, 2008 9:15 am
It looks like there's enough spring left to support the car. If you drive it as it is though you'll probably shred your tyre. If you can get the spring back up onto the support thing its popped off (not good with my technical terms) then you should be okay driving it (for a short distance, and very slowly esp round corners)
Exige V6
Paolo
Post by Paolo » Sat Sep 06, 2008 9:21 am
neil wrote:It looks like there's enough spring left to support the car. If you drive it as it is though you'll probably shred your tyre. If you can get the spring back up onto the support thing its popped off (not good with my technical terms) then you should be okay driving it (for a short distance, and very slowly esp round corners)
Thanks.
Quoted 140 for 2 springs, fitting and VAT. Sound ok??
Matelotman
Post by Matelotman » Sat Sep 06, 2008 9:51 am
I would say it sounds not too bad - £30-£40 each for springs plus labour & VAT
Paolo
Post by Paolo » Sat Sep 06, 2008 9:58 am
Matelotman wrote:I would say it sounds not too bad - £30-£40 each for springs plus labour & VAT
Thanks for your help!! (I'm mechanically challenged!)
Paolo
Post by Paolo » Sat Sep 06, 2008 11:59 am
..surprise surprise - needs new shocks too.
Fook.
