Door Lock issues
Door Lock issues
Got a problem with my door locks on my NA exige.
Press the key fob button once - doors locks
Press the key fob button again - nothing happens!!!!!!!!!
Bit of a pig because i couldn't even get the door open with the key. Had to use strimmer wire to pull the door latch up to get in.
anyone else had this problem - i would imagine it is a east fix though.
BMW Z4M (new toy spec)
Ardent Red Exige NA (sold)
Titanium Grey 231 PS RX8 (sold)
Nissan X-trail SVE (Missus)
Macolloch Turbo SE (Tractor Spec)
For Sale: S2 Alloys and tyres
Re: Door Lock issues
Same problem with mine.
Did a bit of research and it is quite common, maybe the radio receiver for the blipper.
I wasn't confident enough that that was it to buy one though, maybe you could try it first
Malcolm
Malcolm
Sounds sort of reasonable - can't be the mechanisms inthe doors as neither door opens.
anyone know where the radio reciever is located?
- BiggestNizzy
Have you tried new batteries and reprogramming the keyfob ?
embarrassed, um, no.
will do...........
will do...........
This sounds like your central locking module rather than any problem with your key fob. Exactly the same thing happened to mine, and it's a fairly common fault by all accounts.
Mine was fixed at MMC under warranty and I believe it involves a dashboard strip down.
- mwmackenzie
Hmmmm no such problems on an S1
Central locking adds weight and breaks...
Fancy Ass Merc thingy S [R4 MMK] 85% MacKenzie'd Family Spec
Me too!Neil72 wrote:This sounds like your central locking module rather than any problem with your key fob. Exactly the same thing happened to mine, and it's a fairly common fault by all accounts.
Took me 10 mins to get into my S1mwmackenzie wrote:Hmmmm no such problems on an S1Central locking adds weight and breaks...
mind you it looked like a novelty ice cube this morning....
Does anyone know what warranty MMC on Used Cars. Bought my 04 plate of them in Jan. hopifully still covered but knowing my luck!!!!!
You should have got at least a years Lotus Approved warranty I'd have thought... Should have got paperwork for it too...
I have no signature.
Hi,Got a problem with my door locks on my NA exige....
Have you had any luck diagnosing the problem?
I've had a similar issue today with my S2....tried to lock the doors using the key fob and can hear the door trying to lock and the sill button trying to move....but nothing, had to lock it manually! Hoping that its just the low temperatures! Anyone have any further thoughts?? Cheers.
'06 111R Elise SOLD!
Mazda MX6, 2.5L V6 SOLD!
Seat Ibiza 1.9TDI....SOLD!
Audi TT 2.0L TDI......
in both cases it will be the central door locking module. its a very common problem, second to the heater resistor fault its the most common. cheers
