New tyres have improved the situation, no doubt, but I want to get the geo checked anyway and wonder if anyone has real experience of a camber setting to give a balance between road and track.
Assuming (all I can do for now) that the correct camber is currently on the car, tyre wear of those removed would indicate more negative camber would result in a more even wear. The fronts were defintely more worn on the outside. The rears only very very slightly more worn on the outside.
I was thinking of increasing front from -0.1 to -0.5 and the rears from -1.8 to -2.0. I really don't want to have braking reduced with a serious camber. I'd rather be able to brake than corner
It'll be getting done on Monday, so time to consider what to do.
