MOT today: what'll it fail on?
tuscan_thunder
Post by tuscan_thunder » Fri Mar 20, 2009 12:31 pm
Car's getting its Mot today. I expect a fail but nae sure what'll be wrong.
I reckon it'll maybe have some problem with suspension bushes and maybe corroded brakes discs (car hadn't moved for weeks until yesterday and they weren't looking too hot).
It has a year old cat in so I hope the emissions part isn't going to be an issue. Probably be something else wrong as well though
Mair throttle, less brake
Re: MOT today: what'll it fail on?
Post by BiggestNizzy » Fri Mar 20, 2009 12:52 pm
My clio goes in today, having sat for 2 years
wish me luck :D
tuscan_thunder
Post by tuscan_thunder » Fri Mar 20, 2009 1:01 pm
I'll do a trade: you wish me luck, I'll wish you luck!
tenkfeet
Post by tenkfeet » Fri Mar 20, 2009 1:03 pm
Emissions :twisted: Good luck .
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Post by BiggestNizzy » Fri Mar 20, 2009 1:12 pm
tuscan_thunder wrote:I'll do a trade: you wish me luck, I'll wish you luck!
Good Luck :thumbsup
I always have good luck with emmisions :D, apparently dead spiders that have crawled up in to your exhaust work just as well when they burn.
tenkfeet
Post by tenkfeet » Fri Mar 20, 2009 1:32 pm
Emissions is my cars achilles heel , but i have a plan for this year . :wink:
No lotus
Evora S (sold)
tuscan_thunder
Post by tuscan_thunder » Fri Mar 20, 2009 3:12 pm
Nizzy: thanks for the luck! Pass!
Hope you get the same!
tenkfeet
Post by tenkfeet » Fri Mar 20, 2009 3:31 pm
Nice one . :thumbsup
No lotus
Evora S (sold)
Post by Mr Momo » Fri Mar 20, 2009 7:08 pm
Mine in two weeks time - here's hoping Ricky gets through with the emissions (No cat, pre-June 98 kit car, so regs = no cat needed. :? )
Emira - Volvo spec
Post by BiggestNizzy » Fri Mar 20, 2009 8:47 pm
tuscan_thunder wrote:Nizzy: thanks for the luck! Pass!
obviously my good luck wishes where of better quality!
Failed :(
on the way there my wipers packed in, that and my skooshers.
I fixed the wipers but will have to order a new skoosher pump.
bazzam111
Post by bazzam111 » Fri Mar 20, 2009 9:34 pm
Hey John, where did you take the car for it's MOT?????
S1 'Std' Azure Blue (well nearly standard......)
Disco D4 (shiney spec)
Defender 90 (dirty spec)
offshorematt
Post by offshorematt » Fri Mar 20, 2009 9:51 pm
Mr Momo wrote:Mine in two weeks time - here's hoping Ricky gets through with the emissions (No cat, pre-June 98 kit car, so regs = no cat needed. :? )
Pretty sure G got nailed for that one. Doesn't it make a difference if it's Caterham factory built i.e. VIN plates shows it wasn't a kit car...? :?
Either way it's a stupid situation - if big cars are okay as long as they are taxed harder then why are some cars illegal due to the emmisions (waits for some smart arse to explain the difference between oxides, dioxides, sulphates etc etc :lol: )
dlogan
Post by dlogan » Fri Mar 20, 2009 10:46 pm
It does make a difference Mat you are right. Even though its pre-98, if its factory built it needs a cat (applicable back to 91 * It think*), and even with a cat you will need everything crossed and a following wind for a pass Phil. Good luck.
And for your info, Ricky interpreted the "rules" by the book. But depending who mots it, it can seem to be interpreted in different ways.
As I said before, maybe you should be looking at the Emerald sooner rather than later :wink:
tuscan_thunder
Post by tuscan_thunder » Mon Mar 23, 2009 10:10 am
bazzam111 wrote:Hey John, where did you take the car for it's MOT?????
Station Garage, Oldmeldrum. Dealt with them a few times before, no complaints at all.
Post by Corranga » Mon Mar 23, 2009 12:02 pm
Cats (the exhaust kind, not the car, nor the furry variety for that matter) and MOT's are odd.
I assume from what i've read here that a factory built Caterham fits in the catagory with every other car, and needs a car if it was manufactured from 91 onwards.
Obviously the kit car regulations are a bit different, so home built cars are different.
Seems pretty straight forward so far...
We used to have a 1994 Mini Tahiti. Regular 1.3 A-Series engine, but one of the very last with a carb. I queried with my local MOT station about removing the cat (it looked like it was heading towards blowing, and cat replacement pipes were MUCH cheaper than a new cat!)
I was told that whilst the car looked like it was a carb model, it was clearly a fuel injection engine. I argued to the point that the guy told me to bring it in so he could point out my error. When I arrived, lifted the bonnet I recieved an "oh, that's odd" as the mechanic stared at the carb engine :roll:
He then spoke to his boss, and both told me they'd happily MOT a carb engined car, manufactured after 1991 with no cat, as a car is completely useless without the precision of the fuel injection system.
Probably doesn't help you much mind ;)
