Looking through all the receipts etc. for the car I see that in the past it's had a set of verniers fitted.
not knowing much about this side of things, is there any reason to fit them to a as good as standard car ?
Verniers
- BiggestNizzy
Re: Verniers
There is some small reason to do it - but chances are it would have some kind of cam change at the same time.
Re: Verniers
No mention in the Sinclaires receipts about cams being done just "set up cam timing" was done at the same time as a 52mm TB was fitted, and a new cam belt and tensioner although id have thought these would have been done when the pullys were replaced anyway.
I'll maybe have a look under the cover tonight and see if i can see anything obvious on the cams that would make them stick out as having been changed
Oh and i thought a 52mm TB was standard on a S160 ?
Re: Verniers
SVA cars only. Never realised you had an S160; it'll have had the verniers fitted to try and improve driveability.DavieK wrote:No mention in the Sinclaires receipts about cams being done just "set up cam timing" was done at the same time as a 52mm TB was fitted, and a new cam belt and tensioner although id have thought these would have been done when the pullys were replaced anyway.
Re: Verniers
What he said. The S160 is often a total pig unless verniers are fitted ...
