by Mikie711 » Wed Jul 08, 2009 11:24 pm
Just out of curiosity what does the touring pack for the S2 Exige consist of ?. Wondering about fitting the sound proofing to keep the misses happy (ish) as she doesn't like the engine roar you get in these, which I of course love
. But I spend more time with her than the car (only just) so to keep the peace...................
thanks
Mike
by campbell » Wed Jul 08, 2009 11:49 pm
I would doubt how much the sound"proofing" really helps. I'm sure it takes the edge off. But the real solution (other than divorce) is quality earplugs.
Even just the soft rubbery ones that look kinda like layered cones will make a big difference, they are comfy to wear for long periods and you can still hear the CDs and some amount of clear conversation over them.
Try this...
you - "darling, I would like you to wear these for me"
wifey - "you WHAT? you pervert, no chance...I want a divorce"
problem solved
DavieK
by DavieK » Wed Jul 08, 2009 11:59 pm
campbell wrote:
Try this...
problem solved
Unless she takes the car
by campbell » Thu Jul 09, 2009 12:06 am
Well it would solve the problem!
Then you could scrape together the readies for something a bit cheaper but just as much fun...an S1
neil
by neil » Thu Jul 09, 2009 12:24 am
I think the touring pack was just the soundproofing and carpets although I'm probably forgetting something. What exhaust have you got on it? I've got a stage 1 and the touring pack if you want a listen for comparison
Exige V6
by Mikie711 » Thu Jul 09, 2009 1:44 am
I've already got an S1 thanks, and she won't get in that either
neil wrote:I think the touring pack was just the soundproofing and carpets although I'm probably forgetting something. What exhaust have you got on it? I've got a stage 1 and the touring pack if you want a listen for comparison
Might take you up on that Neil, when I get home at the end of the month
Heard of somebody fitting after market sound deadening an supposedly it made a hell of a difference, no idea what type but will try to find out. Can't have here hating both cars
by Victor Meldrew » Thu Jul 09, 2009 3:41 am
She has a CRV to drive around in.. cant see where the problem is.. youll just have top buy here a Porche
ryallm
by ryallm » Thu Jul 09, 2009 6:54 am
Apart from the carpets the Touring Pack also has an extra layer of foam insulation behind the plastic panel behind the seats. Any difference in engine noise compared to a standard car is pretty marginal though - after all there is just a window between you and the engine bay. How about changing to a Europa, or failing that, change the wife
Mark
- Barefoot Ninja
by tut » Thu Jul 09, 2009 8:53 am
Sounds like a valuable lesson in life. Buy the Elise first, then find a suitable wife to go with it.
by BiggestNizzy » Thu Jul 09, 2009 8:59 am
tut wrote:Sounds like a valuable lesson in life. Buy the Elise first, then find a suitable wife to go with it.
although less of the "wife" talk,
by j2 lot » Thu Jul 09, 2009 9:30 am
IIRC as well as the sound proofing,Touring pack had : shelf divider, hand brake 'gaiter' 1/2 leather gearknob and drivers airbag and I think cup holder too. Non of which will appease the other half.
Swap to Europa was what worked in my household
, but not a bad move to make to keep domestic harmony .
cat
by cat » Thu Jul 09, 2009 6:07 pm
I wouldn't waste money on trying to retrofit the OE Touring Pack - been there, done that and ended up very disappointed. You can get much better results yourself with just a bit of time and effort and readily available materials. I'm pleased with the results on my S2 Exige and still have a couple of thing in mind to do. PM me and I'll let you have a blast to see what you think.
D.
'It takes two to lie - one to lie and one to listen' (Homer J. Simpson)
by Mikie711 » Thu Jul 09, 2009 6:10 pm
Na, no way. I'll change the wife before I change this car, at the moment I like the car too much. (hope she doesn't read this
Will have to find out what it was that guy used in his as apparently it really quietened it down. Kinnon?
Cat, offshore till the 29th but once home will do
by Corranga » Thu Jul 09, 2009 6:11 pm
But he already has an S1 to go with his Exige...
