Tyre pressure
undone
Tyre pressure
Post by undone » Wed Sep 09, 2009 6:49 pm
Hi,
Can anyone recommend tyre pressures for a toyota s2 elise with ad07 boots on running on the road?
mmc recommended 29 psi rear
seloc ssay 23F 25R
been having some handling issues at higher speeds since i had to get a tyre changed...
Re: Tyre pressure
Post by tut » Wed Sep 09, 2009 6:54 pm
SELOC correct within 1lb.
steve_weegie
Re: Tyre pressure
Post by steve_weegie » Wed Sep 09, 2009 7:42 pm
I'd say 29 is way too high - Go with the Seloc figures as a starting point.
I've never run the AD07 tyre, but i run 22F 24R on my K S2 with toyo t1r.
Re: Tyre pressure
Post by Victor Meldrew » Thu Sep 10, 2009 1:17 am
Noops and I run ours quite high.(29-31).. however we both have a TPMS fitted and can monitor them and drop out some air if they creep above the upper limit..
And yes 888's do work very well in that range but drop off drastically when you heat them up above 34 psi... and unless you have a TPMS fitted you would never know.
Normal road use, Tut is spot on. You wont go above the drop off point where they stop working if you stick to the recommended figures.
Re: Tyre pressure
Post by alicrozier » Thu Sep 10, 2009 8:45 am
Victor Meldrew wrote:Noops and I run ours quite high.(29-31)..
Are these hot pressures?
Re: Tyre pressure
Post by Victor Meldrew » Thu Sep 10, 2009 12:18 pm
yep, the cut off when hot seams to be above 32psi. Anything over that and they start to go off.
Stewart
Re: Tyre pressure
Post by Stewart » Thu Sep 10, 2009 9:15 pm
Do you not find that they wear round the centre of the tyre much quicker that the outer edges at these "higher" pressures?
Stewart
Re: Tyre pressure
Post by Victor Meldrew » Thu Sep 10, 2009 9:38 pm
Stewart wrote:Do you not find that they wear round the centre of the tyre much quicker that the outer edges at these "higher" pressures?
For me at least, it's more about car feel.
Re: Tyre pressure
Post by Mike Scib » Thu Sep 10, 2009 9:41 pm
But if the centre's are wearing out quicker your not getting a full tyre contact, there for less grip surely?
Re: Tyre pressure
Post by Victor Meldrew » Thu Sep 10, 2009 9:56 pm
It doesn't matter so much about wear when all I'm interested is grip and the car control. The centre
can get hot but it works well. On the road and on the track it gives reasonably even wear accross the whole tyre. For road use you ain't going to meelting rubber like you do on track. Most track sessions I end up with "melted" rubber on the edges. On the road you never get near those temps.
You geo setting will have an effect on tyre temp efficiency. With regard to wear on onside edge or outside edge wear.
For myself and Noops the 29psi target is working well.
Bada Bing!
Re: Tyre pressure
Post by Bada Bing! » Wed Sep 16, 2009 12:28 pm
The 111R manual says 26F/29R and that's what I've run for just over 3yrs. I hate when the fronts go below that as the steering feels all soggy and the car loses a bit of agility IMO.
Gaz
"Ram it baw deep"
