Can anyone help me, my cars booked in tomorrow for mot and just discovered horns not working, checked fuse and still broken. where is the horn located in the s1 elise and is it a big job to change out?
Cheers Bob
S1 horn location
S1 horn location
S1 Elise 111S
Titanium S1 111S (gla)
Joking aside you would probably be best to start with the yellow button, there may be a loose connection in it or more likely a little bit of corrosion which is stopping the contacts meeting properly. If there is a quick scrape would probably sort it. My car has a momo so the set up is probably different but I’d try prising the yellow bit off with a little screw driver and having a look.
I seem to remember that the horn is at the front but can’t remember whether it is accessible with the clam on. Should be easy to swap out if accessible.
Not much use since you are in Aberdeen but I would have lent you one for the day if it was accessible.
Best of luck.
Graham
Best of luck.
Graham
