Shock horror!!!!
Shock horror!!!!
Post by ed » Mon Nov 02, 2009 10:25 pm
Yes, im actually posting in the technical section. :lol:
I lost one of the clips that holds the gearchange cable in place on the way home from picking up the car.
Am i right in saying this: http://www.bell-colvill.co.uk/LotusShop ... A111F6018F is the correct replacement?!
Also considering buying these: http://cgi.ebay.co.uk/TRANSFORM-THE-GEA ... 1e58ef5706
rather than the more expensive eliseparts equivalent.
Is the above worth it?!
thanks in advance cheers Ed :thumbsup
Re: Shock horror!!!!
Post by Mike Scib » Mon Nov 02, 2009 11:59 pm
I fitted the Eliseparts bushes the other week and they made a BIG difference :thumbsup
Post by mwmackenzie » Tue Nov 03, 2009 12:05 am
I bought the Motobuild gear change kit and have no complaints
http://images.google.co.uk/imgres?imgur ... CcountryGB
Post by campbell » Tue Nov 03, 2009 12:24 am
I might have one of the old parts from my std linkage. One or two bits went awol when Robin and I changed it, but if I can find the ones I kept you are welcome to any of it!
Just need to rake it out. Let me know if you are still on the hunt and I will have a proper look. Garage tends to be a no-go area right now...
Post by robin » Tue Nov 03, 2009 8:47 am
I don't think there is more than one type of clip for the elise gearchange, so those ought to be correct.
The bushes are the bit that makes the difference, assuming the rest of it isn't worn out. Dismantle, clean and lube the linkage, replace the bushes for the nylon ones and the linkage will be like new :-)
BTW, check the alignment of the bell crank plate - it can be bent which makes the mechanism less efficient and then makes the stick feel more "mushy".
hiscot
Post by hiscot » Tue Nov 03, 2009 8:53 am
robin wrote: Dismantle, clean and lube the linkage, replace the bushes for the nylon ones and the linkage will be like new
This makes all the difference , you have to retighten the bell crank bolt to remove the slop but not too tight or it will be too stiff
and cable tie the clips in when its done
bob
philthy
Post by philthy » Tue Nov 03, 2009 12:59 pm
Iv got a few lying about too if you can find one.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
danny
Post by danny » Tue Nov 03, 2009 7:08 pm
I have all the clips and bushes from mine when I changed it about a month ago if you need it.
1999 S1 Blue Elise - wee bit not standard spec
2014 Fiesta S tdci - frugal and fun spec
Mountain bike - sore on legs spec
danny
Post by danny » Tue Nov 03, 2009 7:11 pm
Oh and the eliseparts one I fitted made a huge difference, far more positive feel.
Post by tut » Tue Nov 03, 2009 8:32 pm
Bloody right, piece of tin plate.
Tom
Post by Tom » Wed Nov 04, 2009 7:05 pm
ed wrote:Yes, im actually posting in the technical section. :lol:
Get me a couple of those will you? I think you need the 2-part bell crank bush.
1995 Volvo 940SE Estate
