Holy fcuk this thing can shift...
Post by Victor Meldrew » Fri Mar 26, 2010 4:11 am
Looks like I wont be running at this weekends SIDC event.
Dyno day planned for yesterday, lost spark again. Fault traced to a break in the loom. When Dan is fault finding he can also hear a noise from the engine that shouldn't be there. Compression check reveals no.1 cylinder is way down on compression. The engine is blowing back into the inlet on no.1 cylinder on the compression stroke. Suspected cause is corrosion build up on the inlet valve causing it not to seat properly or possibly a bent inlet valve. Regardless the head is coming off again.
Takes a deep breath and blows it out again.. Shopping on Saturday then dear.. :roll:
Last edited by Victor Meldrew on Tue May 11, 2010 10:01 pm, edited 2 times in total.
Re: Loss of compression on one cylinder... nuff said..
Post by Mikie711 » Fri Mar 26, 2010 4:23 am
I have had a similar problem with 2 & 3 cylinders on mine Vic, put it down to valve clearance on mine as all the inlets were tight now the engine is well and truely bedded in. just going to run this one till it goes BANG :twisted: .
New engine in developement, currently finacialy embarrassed which is holding things up a bit. You know how it goes..............
Post by Victor Meldrew » Fri Mar 26, 2010 4:27 am
Mikie711 wrote:I have had a similar problem with 2 & 3 cylinders on mine Vic, put it down to valve clearance on mine as all the inlets were tight now the engine is well and truely bedded in. just going to run this one till it goes BANG :twisted: .
Yep, I know exactly how it goes, you start with a budget in your head and then you can basically double it by the time your done.
Post by Mikie711 » Fri Mar 26, 2010 9:06 am
Double it, I only wish I ended up that close :oops:
Post by robin » Fri Mar 26, 2010 9:17 am
Victor,
What cams are you running on this engine now? Is it still hydraulic or have you got mechanical+shims?
Gourlay83
Post by Gourlay83 » Fri Mar 26, 2010 9:41 am
I know how you feel, when putting my car on the road I hit step back after step back and it does get you down. Hope You/Dan gets it fixed without too much trouble.
Alan
Post by Victor Meldrew » Fri Mar 26, 2010 10:38 am
robin wrote:Victor,
hydraulic lifters, think it's a 285 cam, it was whatever KiwiRog recomended.
Post by robin » Fri Mar 26, 2010 10:44 am
Should have asked the other part of the question first ... has it already run with these cams prior to developing the loss of compression? Anyway, if it's hydraulic then I agree you'll have to take the head off anyway, so kind of doesn't matter ...
Post by Rich H » Fri Mar 26, 2010 10:48 am
Could it be a stuck lifter? Cam ladder off, cams out, buckets out adn have a look/measure? Got to be woth a try before ripping the head off? Will also show if a valve is stuck or not?
Post by tut » Fri Mar 26, 2010 11:23 am
If we lived closer you could have put my head on John, 190hp, 285 mech cams.
roadboy
Post by roadboy » Fri Mar 26, 2010 1:39 pm
Rich H wrote:Could it be a stuck lifter? Cam ladder off, cams out, buckets out adn have a look/measure? Got to be woth a try before ripping the head off? Will also show if a valve is stuck or not?
Already checked that. Pretty sure it's just a sh1tty valve seat. Ho hum.
Dan
SPS Automotive
Independent Lotus Specialists
Post by ed » Fri Mar 26, 2010 9:40 pm
Bad luck matey,best of luck getting it sorted!
Post by Victor Meldrew » Sun Mar 28, 2010 3:23 pm
Suspected cause confirmed. Valves do not appear bent but will be checked tomorrow.
This engine only has to last to the end of this season. Honda conversion and Exige body for next year.
Gourlay83
Post by Gourlay83 » Sun Mar 28, 2010 3:45 pm
Will you still do the Sprint Chanponiship next year then ?
I was thinking of entering my Elise. Against the clock really as I would be in a class with Radicals etc ...
Alan
Post by Victor Meldrew » Sun Mar 28, 2010 10:39 pm
Gourlay83 wrote:Will you still do the Sprint Chanponiship next year then ?
Alan
Yep, will be entering when the car is ready. A few dash mods to sort and the aerodynamics :twisted: to finish and that's me ready.
