I am trying to plug wireless headphones into my TV because I can no longer stand the sound of X-Box gunfire in my living room! The headphones have a standard 3.5mm jack. However, the TV does not have a headphone socket. Having discovered this after I bought the headphones I then order a 3.5mm female to RCA cable. After trying to plug this into both the RGB and CVBS left/right slots with no success I decided the cable was knackered. To test this theory I tried the headphones and converter cable with my Hummy and they worked fine. Not much use though as this only provides sound from the freeview box and doesn't solve annoying-shooting-noise problem. Would I be right in thinking that the RGB & CVBS sockets on the TV are intended for incoming signals not outgoing ones?
I do have a solution for this problem, in that I can stop using an HDMI cable for the Xbox, use the RGB cable instead and instead of plugging the white and red audio cables into the TV I could plug them directly into the headphone stand. However, this is really bugging me and that is a cheating solution and ideally I'd like to be able to use the headphones for the TV as well. I do not believe that a modern TV (even my cheap E-Buyer version) can not be connected to some sort of surround sound system. Therefore, there has to be an audio out somewhere. Doesn't there?
The TV has 2xscart, 3xHDMI, CVBS, RGB & VGA. It also has an SPDIF socket, which I think is something to do with audio output but that uses a coaxial cable. I have no idea what to do with this or if it can be used with some sort of adaptor. This is the link to the manual in case my description of inputs doesn't make sense. http://foehn-hirsch.com/pdf/FH-32LMGverDmanual.pdf
Does anyone have any ideas?
