Toe link upgrade
Kinger
Toe link upgrade
Post by Kinger » Thu May 06, 2010 9:50 pm
Hi
I'm looking to change toe links as I've got a wee bit play in nearside linkage, and as I've now done four trackdays in the couple of months I've had the car I've decided to fit an upgraded kit. Currently looking at Elise parts and Elise shop. The Elise shop one's look a bit more substantial, can anyone tell me where the originals usually fail, i.e. is it the ball joint or locating thread for the ball joint, I suspect it isn't the Tie rod itself. Also are the old ball joints usually hard to split and are any special tools required to break joints.
Re: Toe link upgrade
Post by mckeann » Thu May 06, 2010 10:10 pm
if it were me, i'd go for the eliseparts kit.
I'd make sure you get the rubber covers with it, and make sure you fill them with grease, as even though the instructions says you dont need to, they will develop wear, and they wont be covered by warranty
mikeep
Post by mikeep » Mon May 10, 2010 5:40 pm
http://www.machinemart.co.uk/shop/produ ... tive-tools
Might help you get your balljoints off.
Post by Rich H » Mon May 10, 2010 6:43 pm
Kinger
Post by Kinger » Mon May 10, 2010 9:39 pm
Thanks for the help folks.
mokum
Post by mokum » Tue May 11, 2010 10:56 am
you could try mcgill motorsport in fife, goog prices/service
i got all my joint bits there
http://www.mcgillmotorsports.co.uk
S1 elise oldskool style
petrols organic, must be fine...
