Paint removal?
Take good care of her
fudnie
Paint removal?
Post by fudnie » Sun Jul 04, 2010 9:31 am
I don't know how it happened but I have a big splat of emulsion paint on the front of the Elise.
Does anyone have an idea of how to get it off with out making too much mess of the paint work?
Any ideas welcome, cheers
Craig
S2 111S blue with silver stripes - The Good
56 Astra in black - The Bad
Rover 45 in maroon - The Ugly
Re: Paint removal?
Post by Mikie711 » Sun Jul 04, 2010 10:18 am
If it's emulsion it should just wash off as most are water based therefore not water resistant. Might take a bit of elbow grease but should come off. You could try leaving a wet cloth over the top of it to soften it first.
fudnie
Re: Paint removal?
Post by fudnie » Sun Jul 04, 2010 7:02 pm
That's what I though. Just checking to see if there was a magic cure. Congratulating on the nice new wheels btw :thumbsup
tuscan_thunder
Re: Paint removal?
Post by tuscan_thunder » Mon Jul 05, 2010 10:17 am
maybe pre-soak it with a solution of warm water and car shampoo first. (I'd use a spray bottle with a 20% shampoo, 80% water mix).
give it a good rinse after that or use a pressure washer a low pressure to work off any loose paint.
following that, give it a wash as you normally would (wash mitt, usual shampoo mix) but don't scrub hard or you'll add scratches.
if that doesn't work, I'd try something like Tardis http://www.polishedbliss.co.uk/acatalog ... -cat6.html which is a pretty useful product to have anyway.
let me know if any of that doesn't work.
Mair throttle, less brake
