Access to Heating Gear in ABZ
Gourlay83
Post by Gourlay83 » Mon Sep 06, 2010 10:52 am
Anyone have heating gear or industrial size air gun ( 1" drive etc ..).
I have a hub nut that won't come off, starting to round the hub nut with a breaker bar and 5ft poll. I have removed the hub with C.V joint attached, so can transport it anywhere.
Any help would be much appreciated.
Alan
kpb
Re: Access to Heating Gear in ABZ
Post by kpb » Mon Sep 06, 2010 12:12 pm
There is at my work at Dyce if you can take it there ?.
cheers
Kinnon
Gourlay83
Post by Gourlay83 » Mon Sep 06, 2010 12:34 pm
kpb wrote:There is at my work at Dyce if you can take it there ?.
cheers
Kinnon
I can but have no transport at the moment. Ill speak to Jen when she gets in, see if I can pinch the mini.
Alan
Post by campbell » Mon Sep 06, 2010 1:55 pm
And no resorting to grinders please
Gourlay83
Post by Gourlay83 » Mon Sep 06, 2010 2:57 pm
Thanks Campbell.
Although, nothing wrong with angle grinders. It was the tit using it that was to blame. I have a fear of them now anyway, even the noise gives me flash backs.
Alan
Post by Shug » Mon Sep 06, 2010 3:00 pm
Bad news is you may have to drill and chisel it off...
I had one that we tried inch-drive gear with and even used a welder to heat it up, but it would not shift... Drill, steady hand and a chisel to split - took fooking ages though.
Gourlay83
Post by Gourlay83 » Mon Sep 06, 2010 3:22 pm
Im hoping it doesn't come to that Shug. I've heated them with oxy acetylene until the nut is red hot, thats usually enough to get them moving.
It's only been on 4 days :? i'm not fit to do the work myself so Cheez (big ginger mate) gave me a hand. I don't have a torque wrench that goes up that high (never have) so told him to give it a good tighten. I forgot he's over 6ft and double my weight and there is a big difference between my tight and his.
Alan
Post by mckeann » Mon Sep 06, 2010 3:22 pm
i've seen someone weld a bigger nut onto the hub nut after it got chewed up. Came off after that
Post by campbell » Mon Sep 06, 2010 5:26 pm
Gourlay83 wrote:Cheez (big ginger mate) gave me a hand. I don't have a torque wrench that goes up that high (never have) so told him to give it a good tighten. I forgot he's over 6ft and double my weight and there is a big difference between my tight and his.
Alan
LOL, you will know better the next time ;-)
Sorry for cheap grinder dig, btw, just came out too fast. I didn't fancy using one before your encounter, now I categorically never will as I am bound to be an even bigger t!t than you when it comes to using such equipment :shock:
Post by tut » Mon Sep 06, 2010 8:21 pm
campbell wrote:Sorry for cheap grinder dig, btw, just came out too fast. :shock:
Just stick to the correct type of cheap grinder.......
Post by tut » Mon Sep 06, 2010 8:27 pm
ps Did anybody leave a passenger behind after Tut Towers, or has Old Deer just started going downhill since June?
Gourlay83
Post by Gourlay83 » Mon Sep 06, 2010 11:20 pm
I was getting impatient so Cheez came round to try and drill/chisel it off.
Along took him 30mins :thumbsup Cars on all 4 wheels again.
Alan
P.S No worries Campbell
Post by campbell » Mon Sep 06, 2010 11:26 pm
Gourlay83 wrote: :thumbsup Cars on all 4 wheels again.
Bravo. Which is more than could be said for Tut's a couple of weekends ago ;-)
thinfourth
Post by thinfourth » Sun Sep 12, 2010 8:48 am
I should say i have a set of gas bottles at home for further reference
As well as a few other heavy duty tools for abusing metal
