blacksmith ? soldering of lawnmower handle required.
Technical ... kind off. Broke the handle lifting my rather old but good petrol lawnmower.  Possible to solder it back together i think but do i need a blacksmith to do this ? can anyone recommend someone around the Dundee area ? happy to give it a go myself if some cheap tools can be recommended.
Thanks for any advice.
Scott
Scott
Re: blacksmith ? soldering of lawnmower handle required.
Pics?
I use hard (silver) solder for jobs that need strength but don't need welding.
It will join dissimilar metals to a degree too: steel/brass/bronze/iron (but not ali)
Silver solder (Ebay) + flux (Ebay) + MAPP gas blowtorch (B&Q) is all that's required.
Good idea, will try and upload an image tonight when i get home.Rich H wrote:Pics?
only online for a short while so don't have time to look up a picture/example but if its broken on a straight run a wee tube clamp might do if you really need it. Although at this time of year I recon you'll have a few months to get it fixed
Might be worth your while checking out J Don in Wormit - certainly good for substantial jobs and will fit in smaller stuff. You'll find him opposite the top of Bay Rd.  01382 542379
									A man's got to know his limitations.
embedded images wont work , what have i done wrong ? (looks like this)
[img]http://www.flickr.com/photos/32956185@N00/5081313116/[/img ] (apart from space at end after g)
thanks for the reply by the way chaps. Dont think i have used a soldering iron since 2nd year at high school, happy to give it a go.
PS the hole at the break is redundent, couple of strips soldered ether side would work i think.
How about drilling 2 holes further up (where it starts going tubular) & bolting a brace/strap along the flatter edge, to give it a bit more strength?
									I have no signature.
Not a bad idea ! lose 2 inches on the handle but that could be ok ... im shortgorrie wrote:How about drilling 2 holes further up (where it starts going tubular) & bolting a brace/strap along the flatter edge, to give it a bit more strength?
Just seen the pics.
Batter both sides flat further down and loose a couple of inches of handle?
Or find a bit of tube that fits over the round bit, bolt through and then batter the top bit flat to suit.
That's not a job for solder.
Either get a welder/blacksmith to weld it back together or do a 'bodge' type repair as described above.
- BiggestNizzy
Weld it, with a bit of plate for good measure
						- thinfourth
I'm 45 minutes up the road from you bring it up and i will weld it back together its an easy fix.scott_e wrote:Not a bad idea ! lose 2 inches on the handle but that could be ok ... im shortgorrie wrote:How about drilling 2 holes further up (where it starts going tubular) & bolting a brace/strap along the flatter edge, to give it a bit more strength?
If you feel adventurous you can even have a shot at welding
Which is where i end up spending ages blowing holes in it
I can't weld but I can stick things together with a welder...
Eventually the holes fill themselves if you put enough mig wire in them...
