Anyone got any tips ?
Going to be a 16kw unit with 1.75m of vitreous enamel going in to 4m of double walled, through a wooden ceiling then up through a flat roof.
Any advice and offers of hands much appreciated!
SP
kerryxeg wrote:Hi Sanjoy, I fitted my own before, and learned a few lessons. The heat from a woodburner is seriously hot on the chimney so the chimney has to be in good condition, must have a liner at the minimum. If in doubt it is best to fit a flexi liner. Most prof installers will fit a liner anyway as the diameter of a standard chimney is often to wide to be effective with a woodburner.
16kw is a serious stove, you might want to double check that figure, it depends on the area to be heated etc. I fitted a 9kw stove and it was really too hot for the room, 5kw would have been fine. The other thing to consider is ventilation. Anything over 5kw is supposed to have a direct supply of fresh air from outside. It is a good idea, as the fire is obviously burning the oxygen in the air, and this will be replaced with air through any vent, doorway, floorboard etc that can be found which basically results in lots of draughts. Putting a vent to the fire means that the only additional draught is at the fire and that cold air is soon disposed of.
With a big fire and no vent, I found it dried your eyes out and put you to sleep. I'm now in the process of putting another one in and will be making sure to correct bot problems.
If your looking for a woodburner, my 9kw one will be coming out soon. Not much action or use, black stove style with a little roof one it.
Kerry
