S1 Lotus Badge
puffin
S1 Lotus Badge
Post by puffin » Fri Nov 05, 2010 11:38 am
I drove Glasgow to Edinburgh this morning and when I got out of the car noticed a strange metal "thing" in the radiator grill - the Lotus badge on the nose had come off and been caught in the front cowling!
As I understand it, these are bolted on, and the bolt is intact so the nuts must have loosened over time and fallen into the front clam. Is there a way to refit the badge that doesn't require the clam removal? I'm thinking epoxy resin like Araldite might do the job?
Bad girls don't drive Micras
Re: S1 Lotus Badge
Post by campbell » Fri Nov 05, 2010 11:42 am
If you pop the front grille out (2 placcy fixings on the top, 2 pins that just locate loosely into crash structure on bottom), then you can probably access behind the badge?
Otherwise silicone, araldite etc will all prob be fine for re-gluing I guess.
Re: S1 Lotus Badge
Post by Shug » Fri Nov 05, 2010 12:09 pm
campbell wrote:If you pop the front grille out (2 placcy fixings on the top, 2 pins that just locate loosely into crash structure on bottom), then you can probably access behind the badge?
No you can't, bolts are behind the crash structure :(
Just use something like tiger seal to stick it back on - job done.
Re: S1 Lotus Badge
Post by woody » Fri Nov 05, 2010 12:57 pm
As Shug said :thumbsup Mine's been bonded on for about 4 years now.
There is a technique for removing the badge without removing the clam if the badge is still bolted on; buff down the enamel, mark where the studs are and drill them out.
Re: S1 Lotus Badge
Post by Rich H » Fri Nov 05, 2010 1:27 pm
If you have driving lights the grill will come out, otherwise as above.
If you glue it on scumbags trying to steal it will do less damage...
Re: S1 Lotus Badge
Post by campbell » Fri Nov 05, 2010 3:44 pm
And the saddest thing of all is that my clam was off very recently, and I should have known better!!
Sorry. Having a bad day.
Re: S1 Lotus Badge
Post by Corranga » Sat Nov 06, 2010 6:43 pm
Go for a stick on s2 badge for ease.
Chris
ian974
Re: S1 Lotus Badge
Post by ian974 » Thu Nov 11, 2010 11:20 pm
Hmm, I've got a new badge for mine, but have no idea how much of a job removing the front clam is to get the old one off! This does sound easier in any case! :lol:
