by Ferg » Wed Jan 05, 2011 9:36 pm
I have managed to deliver on one of my new year pledges already. In the few days before going back to work, and with the help from my ever supportive Mrs, we cleared out 3 small van loads of junk from the garage that went to the dump and a variety of other bits and bobs that needed to find other homes around the house or in the garden shed and the end result is that the Elise now has an indoor home!!
It's a bit of a squeeze. I can just about get in and out, and theres very little room at the back of the car, other than to have a tool kit and some other stuff, but the goal of having the car as a second car and living in the garage is completed, well chuffed. I now just need to hook up my solar panel battery conditioner and keep my promise to use the car at least once a week...not hard.
by r055 » Wed Jan 05, 2011 9:54 pm
I miss my garage
by renmure » Wed Jan 05, 2011 10:00 pm
Looks great.
Where will you store the junk now tho
by meatball » Thu Jan 06, 2011 11:44 am
Nice!
Get some carpet on the wall?
by Rich H » Thu Jan 06, 2011 11:54 am
meatball wrote:Nice!
And the floor...
Tom
by Tom » Thu Jan 06, 2011 9:59 pm
Nice! I always wanted a garage for mine and sadly never managed one
As already said, glue some carpet onto the wall. Nothing worse than smacking the door into the wall (ok, there are a few things worse but you know what I mean)
1995 Volvo 940SE Estate
by Mike Scib » Thu Jan 06, 2011 11:07 pm
I really need to empty my garage too, my VX has been lying in my unit for about a month
(that's why I think Mike will do fine, that and his lack of imagination).
by Ferg » Fri Jan 07, 2011 1:23 pm
I've already got an offcut in the wee Merc waiting to go up.
Not sure about the floor though, I've tried that before and when you also use the garage for woodwork etc (car out obviously) a nice concrete floor is much easier to brush.
Might look into those rubber mat things once I've stumped up for another few tins of masonry paint and finished the walls. lol
by j2 lot » Fri Jan 07, 2011 1:41 pm
Garage floor paint is the way to go - stops the concrete dust and looks good too (needs a re-coat every year or so though
by Dominic » Wed Jan 12, 2011 1:45 pm
j2 lot wrote:Garage floor paint is the way to go - stops the concrete dust and looks good too (needs a re-coat every year or so though
Just don't do what my dad did; started brushing / rollering it on; splill some, then decided to empty the paint tin, and 'sweep' the paint across the entire floor; 3 weeks later it still had not dried enough to drive on without it all coming up and sticking to the car tyres
by j2 lot » Wed Jan 12, 2011 1:51 pm
Last time I was doing mine I wondered about just tipping the paint out and spreading it
Forewarned is forearmed.
douglasgdmw
by douglasgdmw » Wed Jan 12, 2011 1:57 pm
If you can't get carpet then Dobbies do this great material (used for green houses to soak up water I think). It has a felt exterior and a green backing - we have covered the garage walls in the stuff (and used load of no more nails) and it does the trick.
It is a little bit thinner than carpet so you get a little bit more clearance to open the doors. If you want some more info I will try and track the stuff down.
George
Alpine A110S
Mini JCW
Range Rover L322 4.4TDV8
Land Rover Series 2a softop
Skyenet
by Skyenet » Thu Jan 13, 2011 1:20 am
Local B&M Bargains shop had pairs of Black and Yellow Foam Padding backed with adhesive tape for a couple of quid. Would give it a nicer finish and especially designed for the purpose.
Vauxhall Astra 1.4 Sports Hatch - not as slow as my old Corsa
by Ferg » Fri Jan 14, 2011 3:46 pm
The foam tiles would be very cool but I think it gets quite dear once you floor the whole garage. Will keep an eye out though.
