Money off Geo in Abdeenshire
Michelle has just pointed out that there is a deal on at Clark Motorsport for getting your Geo done. If you goto Groupon.co.uk, register and choose Aberdeen as your city (or any other city for that matter) you get cheap deals in the local area. The initial check is available for £23 instead of £78 and then as normal your adjustments are extra.
I'm pretty sure the elise needs new shocks so not worth it but the Touareg will be going for a check up.
Re: Money off Geo in Abdeenshire
Bought here too
Anyone know a good track biased S1 set up
Motorsport K20 Elise
Ride/Height 110/120mmfoz01 wrote:Bought here too
Front Camber 1.0
Rear Camber 2.2
Front Toe 0ut 1mm
Rear Toe In 2mm
That's a good starting point, you could be more agressive with camber but it does effect your braking etc ...
Alan
My S1 is on the 340 geo setting (AFAIK)... works nicely.
Also bought but wont be using it on the exige
Cheers Alan, still waiting on the Mot to appear, will give you a shout!
these are good settingsDominic wrote:My S1 is on the 340 geo setting (AFAIK)... works nicely.
Scotty C wrote:these are good settingsDominic wrote:My S1 is on the 340 geo setting (AFAIK)... works nicely.
Perfect...I was going to lower the RS and get a Geo from them...
Cheers for heads up.
Anyone know a track biased setup for an S2 111R. Previous owner did a 'Waspy' setup down south but I do not know what the settings were.
Mini Cooper (wife spec)
BMW dog wagon
BMW dog wagon
Walshy setup maybe? Speak to AndyG he had his 340r set-up by Walshy I think?martins wrote:Anyone know a track biased setup for an S2 111R. Previous owner did a 'Waspy' setup down south but I do not know what the settings were.
Caterham Roadsport 190
Tesla Model 3 LR RWD
"Waspy" was a Sinclaires (now Essex Autosport) setup that they wouldn't give out the details of. Sure it worked well, but can't see it being a magic bullet - I'd get Willie at CLCM in Edinburgh to set it up. Andy just asked him to set it up quick for the 340R and Walshy then went on to say it was the best set up 340R he'd ever driven. For this deal, no idea what the settings were, but Andy might have a record of them (or they might have gone with the car)
I stand corrected!Shug wrote:"Waspy" was a Sinclaires (now Essex Autosport) setup that they wouldn't give out the details of. Sure it worked well, but can't see it being a magic bullet - I'd get Willie at CLCM in Edinburgh to set it up. Andy just asked him to set it up quick for the 340R and Walshy then went on to say it was the best set up 340R he'd ever driven. For this deal, no idea what the settings were, but Andy might have a record of them (or they might have gone with the car)
Merci buckets to all for the input. Will look through all of the paperwork that came with the car and see if there is anything in there....As you can see from my avatar the GEO is definately well out and in urgent need of attention
Martin
Martin
BMW dog wagon
BMW dog wagon
