Steaming
gasgas
Steaming
Post by gasgas » Mon May 02, 2011 10:29 pm
One of the front light pods on my car is steaming up after the car has been run for a while,any ideas on how to fix it or is it a trip to MMC.
Daytona 675
Montesa Cota
Sunbeam S7(long term build spec)
VW GOLF GT TDi
dirkpitt
Re: Steaming
Post by dirkpitt » Tue May 03, 2011 11:41 am
well, my pods where misting up too eric, so the trick i did on my pods was to drill a 4mm hole in the bottom tip end to allow the moister to escape…it works a treat. :D
if you are to do this be very careful when drilling, i would recommend using a hand drill, and gently drill through it.
:cheers leigh
1998 Audi Elige s1-1.8t 20v
LotusLee
Re: Steaming
Post by LotusLee » Tue May 03, 2011 7:41 pm
I had one indicator that used to fill up with water and I just drilled it too , one hole in the bottom to drain and one in the top corner to ventilate.
gasgas
Re: Steaming
Post by gasgas » Tue May 03, 2011 11:50 pm
Brilliant advice,think a steady hand will be needed for this operation,will need to keep off the shandy for a while.Cheers guys :thumbsup
Daytona 675
Montesa Cota
VW GOLF GT TDi
ste7en
Re: Steaming
Post by ste7en » Wed May 04, 2011 9:03 pm
No need to take a drill to your lights Eric.
You have the newer style light pod than Leigh has on his Exige. Check out the second pic in this post on Lotus Talk. You will see that despite these being "sealed" units, there is already a hole in the bottom of the housing. You'll just have some moisture in there which should dry out soon enough with all this good weather we're having.
Noticed both mine were fogged up when out the other evening. Don't think its anything to worry about. :|
Experience is something you get, just after you need it!!
Persian Blue Elise R
gasgas
Re: Steaming
Post by gasgas » Wed May 04, 2011 10:28 pm
ste7en wrote:No need to take a drill to your lights Eric.
Hi Steven,good to know that i`m not the only person with the fogging.Thanks for saving me from the killer driller routine.I spoke to Craig at MMc and he told me to drop by as it`s a quick fix,so i`m planning to take a run through next Wednesday,i`ll let you know how i get on.
It`s been a while since the last Weegie run about time we all got together again,i`ll try and arrange something after the band of rain that`s coming has passed through. Cheers,Eric. :thumbsup
Daytona 675
Montesa Cota
VW GOLF GT TDi
Re: Steaming
Post by Dominic » Thu May 05, 2011 11:39 am
gasgas wrote: It`s been a while since the last Weegie run about time we all got together again,i`ll try and arrange something after the band of rain that`s coming has passed through. Cheers,Eric. :thumbsup
Sounds good! Should give me time to put my car back together (in bits as I'm changing the manifold).
LotusLee
Re: Steaming
Post by LotusLee » Thu May 05, 2011 12:41 pm
Sorry thought you meant the indicator. So whats the fix for the newer headlamps, do they just duct tape the holes :D p.s you had the Montie out recently?
dirkpitt
Re: Steaming
Post by dirkpitt » Thu May 05, 2011 2:14 pm
LotusLee wrote:Sorry thought you meant the indicator. So whats the fix for the newer headlamps, do they just duct tape the holes :D p.s you had the Montie out recently?
soz eric i thought you ment the indicator, as well :) .......my lights have a hole already at the bottom corner and only really mist up if its wet and ive got the lights on...
gasgas
Re: Steaming
Post by gasgas » Fri May 06, 2011 12:25 am
Hi Lee,sounds like this is a common problem,did`nt do any drilling of the headlamps thank goodness.I have`nt had the montie out for ages,you might just have planted a seed of inspiration,last time i took it out i knackered my knee and was out of the game for ages,i`ll need to get it turned over and used.Do you go on any of the runs? If so it would be good to catch up for a blether.
All the best,Eric.
Daytona 675
Montesa Cota
VW GOLF GT TDi
gasgas
Re: Steaming
Post by gasgas » Fri May 06, 2011 12:27 am
Maybe midweek next week,i`ll post up if it`s on.
Daytona 675
Montesa Cota
VW GOLF GT TDi
LotusLee
Re: Steaming
Post by LotusLee » Sun May 08, 2011 4:59 pm
No I haven't been on any SE runs in the Exige :oops: , hope to at some point though.
