I'm selling various bits from my VX220 turbo at the moment, including;
1. Speedline Turini wheels in 16" front and 17" rear, anthracite powder coat with Yokohama A048R LTS spec tyres, 195/50x16 fronts and 225/45x17 rears. The tyres are about half worn having done a couple of track days and a thousand or so motorway miles. The car is still on its original factory camber settings so any wear is even across the tread.
They are Lotus 4 bolt hub pattern and will fit Exige and Toyota-engined Elises. I'm looking for £650 for wheels and tyres. I can take photos and measure the tread depths if there is any interest for them.
2. Eliseparts alloy belled grooved brake discs and part worn Pagid RS14 brake pads, full set of four. I'm looking for £375 for the set. Again I can take photos and measure the pad thicknesses if any interest.
3. And finally, I have Lotus Sport & Performance harness bar, as fitted to the S2 Sport 190 (I believe) and Schroth 6 point driver side harness (wrap around fitting on shoulder straps). The correct size for the Elise/Exige. I'm looking for £175 for both.
I have loads of other things for sale that may or may not fit the later Elise/Exige, including seatbelts and airbag. But posted these items as I thought they might be of interest to the track day regulars.
Gary
Speedline Turini with part worn A048R fitted
Red VX220 Turbo - slightly modified
