S1 111S brake discs
c5tto
S1 111S brake discs
Post by c5tto » Sun Oct 09, 2011 9:07 pm
Im sure this has been spoken about on here but thought would ask question
I currently have a 99 elise 111s which i havent used in a few years and have decided to stick the car back on the road, but will be looking to change the discs and pads prior to putting it for an mot, can anyone recommend where to buy full set of discs and pads for a good price , and also are all S1 brakes the same size etc.
Cheers.
S1 Elise 111S
Re: S1 111S brake discs
Post by robin » Sun Oct 09, 2011 9:31 pm
S1 brakes are the same size.
Lots of places to buy them - EBC are a major supplier of non-OEM disks, or of course you can check MMC prices for the originals. eliseparts, eliseshop, hangar111 are the common online places - easy to check to see who has best deal today.
c5tto
Post by c5tto » Sun Oct 09, 2011 9:41 pm
thanks will have a look on, time to get my lotus back on the road,
S1 Elise 111S
c5tto
Post by c5tto » Sun Oct 09, 2011 10:22 pm
http://www.ebay.co.uk/itm/LOTUS-ELISE-G ... 43a8672c22
came acroos them and wondered if they were any good?
S1 Elise 111S
Post by campbell » Sun Oct 09, 2011 10:29 pm
If that listing is for 4 disks AND pads front & rear, then it's good value I think.
Can't say how good the pads will be though...I have used EBC disks since day 1 but never EBC pads. I always felt that disks for £60 a corner were reasonable value, and that was several years ago ;-) But even if you threw the pads away, that's reasonable VFM for the disks. Didn't check shipping though.
A set of Mintex 1144 pads or Pagid RS42s would complement these nicely.
Note - it may be possible to source a plain disk more cheaply, and if you really want grooves, our own Stu Pollock of Pollock Precision Engineering (stu160 on here) may be able to machine those in for you for a sensible consideration ;-)
Campbell
(S1 owner of 12 years...)
Post by Mikie711 » Mon Oct 10, 2011 12:17 am
That ad is a bit weird, ultimax are disc not pads, the pads mentioned are standard EBC pads. Would recon they would be OK for road use. I fitted the ultimax disc's and 1444 to my last Exige and found them pretty good and didn't break the bank.
TBA
KevD
Post by KevD » Mon Oct 10, 2011 9:01 am
I went with Mintex 1144 pads and EBC plain discs in January. With hindsight I would go for the slightly more expensive ultimax discs - better coating to stop rust on unswept parts.
http://www.eliseparts.com/products/show ... rbo-discs/ You might find them cheaper than there though.
Mintex pads are a big improvement over standard
vet111s
Post by vet111s » Tue Oct 11, 2011 12:53 pm
Euro carparts do pagid plain discs in the correct size and cheaper than ebc. Don't know of quality but I've been happy enough for now. Fitted 1144 discs and been mighty happy so far with stopping power.
Ali
Post by campbell » Tue Oct 11, 2011 12:54 pm
Got a link etc?
vet111s
Post by vet111s » Tue Oct 11, 2011 4:50 pm
Tried to work a link but eurocarparts search engine doesn't seem to create an individual page. Brake discs here ; http://www.eurocarparts.com/brake-disc . They allow you to search using reg number. Coming in at £43.14 for front or rear pair. Seemed like good value assuming theyre not garbage which I'd hope they're not from pagid.
Ali
Post by campbell » Tue Oct 11, 2011 4:53 pm
Leave the notification email marked as "unread"...that tends to jog my memory ;-)
Tom
Post by Tom » Tue Oct 11, 2011 11:44 pm
c5tto wrote:http://www.ebay.co.uk/itm/LOTUS-ELISE-G ... 43a8672c22
These aren't Ultimax (IIRC) as the grooves are wrong, and they should be black (colour due to a coating that helps prevent the unbraked areas from rusting). <EDIT just re-read link and it's a stock photo :oops: >
These are what you want http://www.ebay.co.uk/itm/EBC-ULTIMAX-F ... 1c1be5bf25
I haven't used that seller but others may have. Not sure about price as I bought my last in summer '09.
As for pads I'd get the Mintex that people talk about if you don't want to spend too much. I've always felt that brakes aren't worth skimping on and bought Pagids (or Carbon Lorraines these days). Think the CL RC5 (or whatever they're called) are well worth the money. Ask Ferg on here, Mintex I'm sure are ok, but the Pagid/CLs are in a totally different league.
1995 Volvo 940SE Estate
