Hello everyone,
I read on the site that MMC will reflash your ecu to the lotus spec, lower the cam change. However as i have odered the bwr supercharger i would need a more special reflash. Do you know pf any companies in the uk that have cracked the lotus ecu software and have a reflash for the bwr kit??
I know of charlie x in the states but since its my everyday car i would like to avoid having it stationary for a month.
Regards,
Marios
ECU Reflash
Re: ECU Reflash
Contact essex motorsport as they do the Charle X modifications and have full access to the ecu. You will need to get the car to them Im afraid for mapping unless they have a similar setup which you can try. I did this with them, sent them the ECU and they flashed it with a setup from a similar car. When I got it back I ran it with a wideband and checked the AFR, unfortunatly it was quite a bit out and I ended up going down for a RR session. You may be lucky and find its just running lean or rich across the entire range in which case you could use an adjustble FPR to get it close but it will always be a compromise.
Craig.
Craig.
Hairdresser at heart.
Re: ECU Reflash
Craig thanxs for the reply. Unfortunately i live in greece so taking the car to then is no option for me. I know a couple of guys from athens that sent the ecu to the states and had no issues afterwards. I ll give essex motorsport a call tomorrow and see what they say. Thanxs again.
