Polished Bliss®: 1969 Aston Martin DB6 Volante
Take good care of her
tuscan_thunder
Post by tuscan_thunder » Tue Oct 18, 2011 11:13 am
I meant to stick this up when we did it a while ago but forgot but better late than never!
A slightly different car and all the better for it!
From here on, it's all Clark's text.
Enjoy!
It's been a while since we had an older car in and what a beauty it was!
Today with a value of circa £350,000 it also has a massive amount of sentimental value as it has been in the family since it was brand new, however it is no garage queen and actually does more annual miles than my Impreza :o
The car was booked in for an Enhancement Detail so after closely inspecting the car for anything to be avoided when washing I began with the wheels:
Wolf's Deironizer was applied and left for 5/10 minutes:
The wheels started to bleed almost instantly:
Agitating the product to get the best out of it with all the various brushes:
I started thinking back to when I spent nearly 2 days with a dremel on a set of very similar wheels on a 1965 Maserati a few years ago and thanked my lucky stars that these ones were in much better condition!
After a thorough rinse off:
APC (4:1) was then used to clean the tyres and arches:
Rinsing at low pressure:
The car was just a bit dusty so no real need for a pre-foam, using APC again I went round all the badges/grills etc...
...before washing with the 2 bucket method...
...and then thoroughly rinsed off:
The car was then moved inside for a bit of spot claying with Meguiars Mild Detailing Clay:
I then used the Black Baron to dry everything off and applied Swissvax Pneu to the tyres:
It looks real messy just now but it soon soaks in to leave a really nice finish, especially on larger profile tyres such as these:
I then turned my attention to the hood, firstly spraying Swissvax Leather Cleaner...
...then working small sections at a time with a Swissvax Leather Brush:
This removed a fair bit of grime and the difference was plain to see:
All cleaned up:
Nanolex Convertible Top Sealant was then applied and left to fully dry:
Water beading once fully dry:
Onto some paintwork polishing now :)
Some examples of the defects:
Being an Enhancement Detail I obviously wasn't after full correction but after initial tests, it quickly became apparant that I was going to have to use a fairly strong combination just to get an improvement in the finish - this paint was HARD, proper old school paint :D
Menzerna 3.02 with a LC Polishing Pad & the Makita @1800rpm's were the weapons of choice:
3.02 is still one of my favourite polishes and provided it's thoroughly worked you can use it as a one step product on most paints and produce a finish 99%equal to that of a dedicated finishing polish. As the paint was so hard on this Aston it finished down trail free very easily.
Correction wise, on the worst parts I'd say I got a 50/60% improvement and in best cases the paint was pretty much flawless.
An example of the 50/60% areas...
Before:
After:
And a few other random correction shots:
Before:
After:
Before:
After:
The number plates (these are the original ones) were quite dull so these were machined too.
Before:
After:
Tail lights before:
After:
There was a bit of dirt build up inside the lights so I removed these and gave them a thorough clean inside and out with Auto Finesse Tripple. I didn't appear to take an after pic from the same position but you'll see they're awfully shiny in the afters later on :D
Once polishing was done I used a lambs wool duster to remove any dust:
Rejuvenate was then used to prep the paint for waxing:
Spirit was the wax of choice to protect the paintwork:
With pretty much most of the exterior done, I turned my attention to the interior. The rear screen was quite dull and hazy so armed with some Poorboys Black Hole and a MF pad I started to make a big improvement.
Right side done, left side untouched:
All done:
The hood was then put down to make it a bit easier to see what I was doing on the interior. For a 42 year old car I was amazed to find the hood was electric!
A few bits were removed such as the mats and rear bench:
A Swissvax interior brush was then put to good use for dusting out all the nooks and crannies:
Followed by a thorugh hoover:
The leather was then carefully cleaned with Swissvax again, here you can see the passenger seat has been done with the drivers side still to do:
Door cards done too:
The pedals were cleaned up with some APC and a triple duty brush:
Leather was then fed with Swissvax Leather Milk:
Any Leather cleaner residue on the chrome work was removed with some IPA on a cotton bud:
Again using a cotton bud to clean round the gear stick:
Mats put back in after being cleaned and then protected with Nanolex:
Interior complete:
With the roof put back up I cleaned up the chrome parts with Auto Finesse Tripple...
...And polished up the grill with Swissvax Metal Polish:
It goes without saying that on a car like this I could spend several hundred hours if I was let loose but over 2 days I had to make sure everything on the car was done in the time provided, as a result some parts maybe aren't as detailed as some would like but if there are any questions then fire away :thumb:
Here's the result after 2 long days, it was dark by the time I'd finished so unfortunately it's only inside shots:
Thanks for looking :)
Mair throttle, less brake
Re: Polished Bliss®: 1969 Aston Martin DB6 Volante
Post by j2 lot » Tue Oct 18, 2011 12:20 pm
As ever fantastic work. Car looks gorgeous :thumbsup
Post by tut » Tue Oct 18, 2011 1:05 pm
I love these posts, especially on such a classic and old car as this Aston. You expect a newish Ferrari to look pretty good anyway, but to get a 42 year old car to look like this after only a partial process is something else.
Great job guys.
tuscan_thunder
Post by tuscan_thunder » Tue Oct 18, 2011 1:23 pm
We must be doing something well when the Barefoot Ninja's praising detailing work! :damnfunny
Seriously, thanks for the comments; I agree, I personally find jobs like this more satisfying as you see a more marked improvement. The slight frustration, as Clark said, was that we could have spent 100s of hours on this car to make it flawless so drawing the line with it was tricky but I think we got a good balance between restraining the cost/time and getting the right result.
A really nice car, I have visions of swanning round the South of France in it
Post by tut » Tue Oct 18, 2011 2:04 pm
I remember one of your first posts John.
tuscan_thunder wrote:I do a bit of valeting in my spare time.......
I never owned an Aston, but in '73 I had a two year old V12 E-Type and a friend from Oman had a three year old AM DB6V, which we both paid silly money for, ie not a lot. As we came back on leave at different times we had the choice of both of them. Not much point in saying on hind site that we should have stuck them in a cocoon for forty years.
Post by Mr Momo » Tue Oct 18, 2011 6:21 pm
8)
That is beautiful - lovely colour and great finish - I think the first few photos with the wire wheels set-up a good thread.
I think you got that right combination of detailing for this car. It's obviously not concours (no offence I hope), but you get the impression that it is well loved and used.
Hope your customer was impressed.
Emira - Volvo spec
Post by Andy G » Tue Oct 18, 2011 11:10 pm
Wow. Hats off. What an effort.
I don't think what I do counts as washing let alone cleaning! :damnfunny
tuscan_thunder
Post by tuscan_thunder » Wed Oct 19, 2011 10:41 am
Tut; yes, things have moved a wee bit from 'valeting on the side'.....!
Your story about the E-Type and DB6V reminds me of my dad telling me when my granda looked at a Daytona for something like 7grand but turned it down.....
Mr Momo; you're absolutely right; it's not a concours car and the owners don't really want it to be; it's been round Knockhill in the past few years and gets used properly. He just wanted some love lavished on it and a good improvement given to the overall appearance/condition of the car which I think we achieved; if it was concours I think it'd almost be a shame to use it fully, this way, it's probably the best of both worlds.
Thanks to all for the kind words (on this thread, and others I've put up); this is what I love about putting write-ups like this on SE; there's no 'what a waste of time' comments. Even people who aren't detailers and maybe scarcely wash their own cars appreciate the work and results. It's not like that on many forums! A better class of user on here!
Post by Mr Momo » Wed Oct 19, 2011 6:15 pm
Could stick a set of 22" Kahns on it - bling it up a bit
Emira - Volvo spec
Post by Dominic » Thu Oct 20, 2011 1:19 pm
Stunning car! :love And great work guys :thumbsup
Post by tut » Thu Oct 20, 2011 5:27 pm
tuscan_thunder wrote: Your story about the E-Type and DB6V reminds me of my dad telling me when my granda looked at a Daytona for something like 7grand but turned it down.....:)
Must have been about the same time that I was looking for one John. I came back from Oman in '77 with Verian in tow and set out to buy a Daytona GTB which were going for around £6K at the time. Knew it would take time so bought a new Alfa Sud for a couple of grand, then started searching the ads. Not exactly the same as looking for a Ford, but went and saw two, either would have been great, but we had bought a house in Derby between us, supposed to be on a six month trial of living together but obviously she knew she was onto a winner, so we got married and the Daytona never came about.
smee
Post by smee » Wed Oct 26, 2011 8:49 pm
I think this guy's son is a friend of Iain Mac on here? Do they also own a gold targa 911 that has also been in the family since new?
S1 Elise - LRG MMC
Exige 390 LRG
GR Yaris
Leighton T6.1
tuscan_thunder
Post by tuscan_thunder » Thu Oct 27, 2011 10:18 am
Not sure to be honest.
Obviously we can't disclose customers' details but it wouldn't surprise me if they had a few cars; they seem proper petrolheads! Really nice folk too.
