S2 heating control backlight
colintinto
Hi All,
Trying to adjust my heating controls last night, I realised that they used to light up?
Hard to tell, but it looks like there is still a bit of a glow that comes and goes.
Anybody had/fixed this issue?
Tesla is coming...
2007 Volvo XC90 (everything fits inc. kitchen sink spec)
2012 BMW X1
2012 BMW X1
Re: S2 heating control backlight
I don't think they do, mine certainly don't. Seems like that would add undue weight
I just checked mine and it doesn't light up either. Not sure that it ever did.
Just got an email about this from our friendly neighbourhood MMC service manager (he reads, but can't post)
"....It will be the switch pack behind the satc unit as it provides the power to the circuit ..Common also easy to confirm if the re circulation switch doesn't illuminate."
So, if your recirculation switch isn't lit up, then it's likely a switch pack and a common fault - not sure how easy it is to get at, but with what Craig's saying, I'd guess dash off?
Recirc? Colin do you have a/c?
My one packed up on day one of ownership of an S2. New pack required.
Sent from my Galaxy S2 using Tapatalk
DEL
2022 Hyundia i10 N-Line
2019 DS3 Crossback
2019 DS3 Crossback
Ah, to clarify my post from Craig, satc was a typo - it's behind the Stack. So no full dash off, just the stack.
colintinto
Don't have AC, but checked again the other night, and it's not totally gone, but comes and goes, so something is loose or failing.
Guess that's the solution then!
Colin
Colin
Tesla is coming...
2012 BMW X1
2012 BMW X1
- alicrozier
I think it would be worth checking the connections behind the heater controls, I've had experience of these coming loose.
It's simple 2 screws to remove the cover, so only 5 mins to check...
