Fixing a wing mirror
undone
Post by undone » Mon Mar 26, 2012 6:05 pm
Hi all
Anyone got some advice for fixing a wing mirror? Some wee ned decided to rip mine off leaving the assembly in two parts on the floor and one of the black plastic prongs still stuck in the door. Do you guy reckon a couple of dabs of epoxy will hold it fast enough or am I looking at a new wing mirror?
Cheers for all the help!
cjm
Re: Fixing a wing mirror
Post by cjm » Mon Mar 26, 2012 6:19 pm
Someone snapped mine off a month or so ago. I ordered a second hand metro mirror from eBay and swapped the broken part over. I think it was about £10 and the cost of the torx allen keys to unscrew the broken prong.
Split the mirror in to two parts, disconnect the long spring and swap the broken parts over, the new part did need the prongs cut to the correct length and the adjuster cut off but that only took five mins. I then used a bit of string round the end of the spring so I could stretch it back into place.
The link below should have a few photos, which might help with my awful explanation!
http://www.scottishelises.com/phpbb/vie ... 29#p389529
Colin
10-15 S2 Elise 111S
17-23 S1 Evora
whaleys
Post by whaleys » Tue Mar 27, 2012 11:09 am
You're much better off getting a new mirror and transferring the body coloured casing. They are fairly cheap (just a Metro mirror) and it's much less likely to fall off a month down the line :) loosing your body coloured section in the process.
Graeme
undone
Post by undone » Tue Mar 27, 2012 5:09 pm
Good point Graeme! Thanks Cjm for the quick reply.
cjm
Post by cjm » Tue Mar 27, 2012 5:49 pm
Yes that is what I did, just swap the snapped parts and keep the coloured back of your mirror so you didn't need to have anything painted.
Colin
10-15 S2 Elise 111S
17-23 S1 Evora
