S1 boot release
Noops
S1 boot release
Post by Noops » Thu May 24, 2012 8:35 pm
Is the sun affecting my head :roll: , how is the part that catches the cable release has the spring and the big washer attached to the boot lid ?? came home after a quick nip to the shop to find the boot lid and that part detached :? no sign of a nut /fastening inside the actuall boot lid housing :?: . Rooted about in the boot to see if a nut had dropped out but nothing. :?:
The cable release part is working fine
Noops
Re: S1 boot release
Post by Stephen » Thu May 24, 2012 9:55 pm
is it not just a threaded insert?
Noops
Re: S1 boot release
Post by Noops » Thu May 24, 2012 10:23 pm
Stephen wrote:is it not just a threaded insert?
I thought that as well :? , but its as if the insert has dissapeared and left behind a hole nice neat hole the size of a 20p which you cannot thread , I might insert a dowel of some kind and see if that cures it :wink:
Re: S1 boot release
Post by alicrozier » Fri May 25, 2012 9:11 am
http://www.deroure.com/diagrams.asp?TBL ... 0&ST=&SC=0
Item 02 B111U0032F M10 floating nut plate
Looks like it's floated off somewhere?
Re: S1 boot release
Post by Corranga » Fri May 25, 2012 9:13 am
I'm fairly sure it's a rivnut into the boot lid, then a bolt to hold on the latch - though I might be thinking about the hinge end as I had to drill out and replace 2 of the 3 hinge end ones on mine as the threads were shot.
Noops
Re: S1 boot release
Post by Noops » Fri May 25, 2012 10:28 pm
Many thanks to Stephen C for calling this morning to offer help :thumbsup . After a good look I found the missing part down past the engine sitting on the undertray ready to fall onto the road ..it must have slipped out as I lifted the boot to check.
All working again :thumbsup
