toms requires help again!
Post by ed » Tue Aug 29, 2006 4:41 pm
his shed :P is getting the geo done on fri and he would like to know what the factory settings are for a standard car and the 160 and anything in particular he should say to mark etc etc.
cheers! :D
Post by GregR » Tue Aug 29, 2006 4:47 pm
pinched from the dark, dark place:-
340R settings:
ride height: front 100mm/rear 110mm
steering axis inclination 12° nominal
castor +3.8°
road use
front camber -0.5°
rear camber -2°
front alignment 0.2mm toe-out overall
rear alignment 1.5mm toe-in each side
dry track use
front camber -1.8°
rear camber -2.7°
front alignment 0.5mm toe-out overall
rear alignment 2.5mm toe-in each side
Rob E settings:
ride height: front 105mm/rear 115mm
castor left 3.52°/right 3.42°
front camber left -1.17°/right -1.27°
rear camber left -2.12°/right -2.33°
front alignment left -0.4mm/right -0.3mm
rear alignment left 1.9mm/right 2.1mm
Bob van M suggested settings:
ride height: front 110mm/rear 115mm
castor 4° 10' front
front camber -1.4°
rear camber -2.42°
front alignment 0.6mm toe-out overall
LSS settings:
castor 3.8° front
front camber -0.3°
rear camber -2.0°
rear alignment 1.2mm toe-in each side
Simon S suggested settings for the given ride height:
ride height: front 115mm/rear 125mm
castor 3.8° front
front camber -1.0°
rear camber -2.0°
front alignment 0°15" toe-out overall
rear alignment 0°30" toe-in overall
std S1 settings:
ride height: front 140mm/rear 140mm
castor 4° front
front camber -0.1°
rear camber -1.8°
Post by ed » Tue Aug 29, 2006 4:48 pm
wicked ta muchly! :thumbsup
Post by Rich H » Wed Aug 30, 2006 2:26 am
Forget the castor settings unless he is going for a major geo sesh. Involves wishbone bolts and all that joy. The Gordon Lite is what I have, very pointy but ot agressively so:
-1/-2
0.5mm out/2mm in
Castor as it comes, mine was ~3.4/3.8
Apparently the toe in on the rear increases chuckability and cornering confidence but too much will kill the car and make it feel dead, toe out will improve turn in but too much will make it too twitchy.
Camber will improve cornering grip but decrease straight line grip and tyre wear on the inside shoulders.
Take your pick, but I wouldn't bother with the extremes or the standard. A tiny adjust makes a world of difference. Most of what can be achieved in camber depends on the shims available. I have some extra read shims if he wants but I would imagine he will want more agressive camber not less.
Good luck
