Running lean at idle
paulW
Post by paulW » Tue Jul 17, 2012 12:36 pm
Ok, since fixing manifold gasket and fitting a new working wideband (plx this time :mrgreen: )
I am running lean at idle. :cry:
rest of rev range is ok, but at idle it starts off ok and then gradually gets leaner and leaner, until it starts to sound rough.
any ideas? I am guessing MAF sensor? which i may have a spare if i can locate it.
paulW
Re: Running lean at idle
Post by paulW » Tue Jul 17, 2012 12:40 pm
suppose it helps if hose is actually attached to inlet plenum :oops:
Post by Dominic » Tue Jul 17, 2012 12:51 pm
Glad I'm not the only one who does these things! :oops:
Post by campbell » Tue Jul 17, 2012 12:51 pm
Don't be too hard on yourself, Paul ;-)
paulW
Post by paulW » Tue Jul 17, 2012 12:53 pm
nice rich cold idle that goes to 14.5 when warm...guess that is that fixed then. :mrgreen:
dirkpitt
Post by dirkpitt » Tue Jul 17, 2012 4:16 pm
:damnfunny ......dont mention it... :thumbsup
1998 Audi Elige s1-1.8t 20v
KingK_series
Post by KingK_series » Thu Aug 23, 2012 1:10 pm
Dominic wrote:Glad I'm not the only one who does these things! :oops:
You have brilliant company on seloc...... I really wouldn't worry, and the best bit is you will never have that problem again!
Post by robin » Thu Aug 23, 2012 1:42 pm
paulW wrote: any ideas? I am guessing MAF sensor? which i may have a spare if i can locate it.
For reference, the K doesn't have a MAF it has a MAP; on S1 it's built into the MEMS1.9 ECU; in S2 and VVC engines it's built into a combined pressure/inlet temperature sensor that's located on the right hand (drivers) end of the inlet manifold.
KingK_series
Post by KingK_series » Thu Aug 23, 2012 1:55 pm
Yes and they are generally very reliable, I have known 1 go down so far, completely threw the running and made the engine very difficult to start.
