Getting the Exige on the Ferry
SAJ
Post by SAJ » Mon Feb 11, 2013 11:05 pm
I'm thinking of taking the Exige with me over to Northern Ireland in the summer but was wondering if it would have any clearance issues getting on the Ferry. Stats in the image below.
Most likely it will be from Troon to Larne and same route on the way back.
Instagram: @RevLimits
neil
Re: Getting the Exige on the Ferry
Post by neil » Tue Feb 12, 2013 10:14 am
You'll not have a problem as long as you take it at an angle - it cant be any worse than the 2-11s are.
Exige V6
douglasgdmw
Post by douglasgdmw » Tue Feb 12, 2013 11:44 am
There is a more "General" way that Orange vehicles can get on a ferry:
Hope it works on yellow?
George
Alpine A110S
Mini JCW
Range Rover L322 4.4TDV8
Land Rover Series 2a softop
SAJ
Post by SAJ » Tue Feb 12, 2013 1:38 pm
neil wrote:You'll not have a problem as long as you take it at an angle - it cant be any worse than the 2-11s are.
Do you know someone who has taken a 2-Eleven on the Ferry and also any idea what ride height they are at the front?
neil
Post by neil » Tue Feb 12, 2013 1:48 pm
Scotty/Stu's shed has been on the Newcastle & Harwich ferries. Dont have a clue what the ride height is but it'll be lower than a V6 Exige and with the plank of a splitter on the front the angle of attack will be worse. The guys on the ferries tend to be pretty good and will guide you on.
Is the V6 lower than the S2? I've had mine on many ferries without any issues. The Corran is probably the worst I've seen any even it's fine if you take it at an angle.
If you're that worried you can take my RGB over for the weekend and I'll look after your V6 ;-)
Exige V6
SAJ
Post by SAJ » Tue Feb 12, 2013 2:02 pm
neil wrote:Scotty/Stu's shed has been on the Newcastle & Harwich ferries. Dont have a clue what the ride height is but it'll be lower than a V6 Exige and with the plank of a splitter on the front the angle of attack will be worse. The guys on the ferries tend to be pretty good and will guide you on.
Cheers, sounds fine.
Post by alicrozier » Tue Feb 12, 2013 2:18 pm
2-11 ride height is 100/110 as standard. I'm sure Scottys is/has been lower.
Newcastle never been an issue. You always get looked after. :thumbsup
Post by Gareth » Tue Feb 12, 2013 7:59 pm
Just teasin! :-)
AiD
Post by AiD » Tue Feb 12, 2013 8:39 pm
If you take the new ferry from Cairnryan you will have no issues, you barely notice there is a ramp on!
SAJ
Post by SAJ » Tue Feb 12, 2013 9:29 pm
Gareth wrote:Image
Just teasin! :-)
AiD wrote:If you take the new ferry from Cairnryan you will have no issues, you barely notice there is a ramp on!
Good to know, I have considered going from Cairnryan too.
That's quite reassuring so looks like it is all go for me.
Thanks for all the input.
shooomer
Post by shooomer » Tue Feb 12, 2013 10:51 pm
I got on and off that ferry with very low car. They asked me to park at door to avoid ramps inside the boat :thumbsup
SAJ
Post by SAJ » Wed Feb 13, 2013 9:03 am
shooomer wrote:I got on and off that ferry with very low car. They asked me to park at door to avoid ramps inside the boat :thumbsup
Was that Troon or Cairnryan?
shooomer
Post by shooomer » Wed Feb 13, 2013 9:31 am
Troon
SAJ
Post by SAJ » Wed Feb 13, 2013 1:29 pm
shooomer wrote:Troon
