BMW Electric Seat Broken - Flexible Shaft
a4drk
Post by a4drk » Mon Apr 22, 2013 6:33 pm
The electric seat on my 335d Coupe is twisting when you move it forward & back
One side isnt moving - it pivots & twists
The seat is out & the motor is off it
There are 2 flexible drive shafts which pop into either side - one is 100mm & the other is about 200mm
(200mm one is fine)
Pic below of the broken 100mm one.
There is a 3mm square end which pops into the motor & the cog on the runner
BMW dont sell these separately -you have got to buy a complete new subframe / runners for the seat @ £700 !
I'm was thinking if this could be repaired ? - Brazed maybe ?
Or does anyone know of anywhere that makes / supplies these ?
It needs to be flexible as the seat goes up & down too
any help much appreciated
Thanks
David
Uploaded with ImageShack.us
S2 Exige
Doc883
Re: BMW Electric Seat Broken - Flexible Shaft
Post by Doc883 » Tue Apr 23, 2013 10:41 am
a4drk wrote:The electric seat on my 335d Coupe is twisting when you move it forward & back. One side isnt moving - it pivots & twists
BMW dont sell these separately -you have got to buy a complete new subframe / runners for the seat @ £700 ! Thanks David
Sorry can't help on your seat problem but the complexity of modern cars has to be a real worry for future owners years down the line.
My brother in law had a Tdv8 RR Sport that cut out on the Stonehaven by-pass. Aberdeen LR had the car for weeks trying to diagnose the fault including hoisting the body off the chassis :shock: In the end an expert from the factory was shipped to Aberdeen to help. Luckily for him he had a LT extended warranty as the bill was north of £10k. The car broke down again days later with same symptons so he rejected the car and LR took it back.
a4drk
Post by a4drk » Tue Apr 23, 2013 10:23 pm
I found the company who makes these for BMW.
The are based in Switerland & are called
www.suhner-transmission-expert.com
Basically I got an email back from them saying that they are contracted to only make & sell them to BMW !!! :twisted:
anyway, also found another place.
not heard back yet
http://www.biax-flexwellen.de/en/Einsat ... eugbau.php
theres a photo there of exactly what i'm after - so fingers crossed
and also fingers crossed its going to cost me less than £700 !
David
S2 Exige
Post by Sanjøy » Wed Apr 24, 2013 8:21 am
Breakers?
a4drk
Post by a4drk » Wed Apr 24, 2013 8:43 am
Tried that Sanjoy ,
Sent enquiries thro all the major breaker website / search engine websites
Thinking of getting something made - along the lines of a thick piece of cable
And welding 2 blobs on each end and filing it down to fit
Where's Rich from Preston ? This is up his street....
David
S2 Exige
Post by Sanjøy » Wed Apr 24, 2013 9:32 am
It looks like the flexy stuff you get with power screw drivers if that helps at all ?
a4drk
Post by a4drk » Wed Apr 24, 2013 9:34 am
Yeah, got one of those, but I think it needs to be thinner
S2 Exige
ryallm
Post by ryallm » Thu Apr 25, 2013 8:36 am
Can't help you on the problem, but curious to know how you like the 335d. Been pondering buying a 335 or 330d (later 245 version) for a while now.
Mark
Post by BiggestNizzy » Thu Apr 25, 2013 8:44 am
Scrappies ?
a4drk
Post by a4drk » Thu Apr 25, 2013 8:58 am
@mark - remember the 335d only comes in auto (with the flappy paddles)
The 330d comes manual and auto
This is my first auto that I've owned & love it.
335d is 286bhp & 428 lb ft torque
However the 330d is still a quick car too - the newer 245bhp with a remap takes it up to 335d figures
Still gets 35mpg horsing it !
If you want a shot of it you are more than welcome
David
S2 Exige
a4drk
Post by a4drk » Sat Apr 27, 2013 6:27 pm
I think Ive sorted it !
I had some 10mm Twin & Earth Cable - which is the heavier than normal stuff you use for electric showers (for 10.8kw)
anyway, cut a bit off & cut 2 strands off
Each strand is about 1.5mm thick
Then i dipped it in flux & coated it in solder. I filed it down on a bench grinder till it fitted in the motor.
When i got to the other end, I took the sleeve off & just removed the 2 unused strands.
sleeve back on and soldered & filed.
It fits in & the turns the motor & its flexible !
Car is booked in on Monday to get put back together - so fingers crossed - i'm £700 better off for 15mins work.
David
S2 Exige
Post by j2 lot » Sat Apr 27, 2013 8:54 pm
Well done- got to love Heath Robinson fixes that cost nothing but ingenuity and save £££££ :thumbsup
neil
Post by neil » Sun Apr 28, 2013 11:16 pm
Top bodging! :thumbsup
Exige V6
Post by Dominic » Mon Apr 29, 2013 9:41 am
neil wrote:Top bodging! :thumbsup
ClarkyBoy
Post by ClarkyBoy » Mon Apr 29, 2013 12:09 pm
Cracking engineering there,
well done :thumbsup
glad to see there are still people out there with some ingenuety :-)
(and hopefully there are a good few spellists out there that can deciper my spelling :-) )
Vanlife Sprinter
E30 318is / axle stand spec
987.2 Cayman S
[#]=///=[#] ‘88 Panda 4x4
BSA B31
MF35
Stiga Tornado
Many Bicycles
