Special K - a rather standard rebuild
Post by campbell » Tue Apr 23, 2013 6:49 pm
So out of sheer guilt, I have neutralised my thread hijack of "Alloy vs Steel uprights" by starting this one.
Now, it could be soon, or it could be a long way off... but the boffins reckon UJI's broadly stock K Series will need a rebuild before long. 100k miles in, whilst all *seems* well in broad terms, the Murray Magicians have detected a small water leak "somewhere around the flywheel area" IIRC.
Prob just a warning shot, but it pays to pay attention to such things.
After talking to Q (that's Robin) at length a year or two back, a ground up rebuild but with some selected engineering tweaks for strength was what we settled on. Don't need more power, don't need a racing engine. Just want another 100k plus out of this one and the option for the kids to drive the car one day.
So we have just 11 years to complete the project then :damnfunny
Robin has been weeing on a donor block already, it seems.
I'm keeping the head.
So what else to plan in...?
KingK_series
Re: Special K - a rather standard rebuild
Post by KingK_series » Tue Apr 23, 2013 8:15 pm
Re: Alloy vs Steel uprights on S1
Postby campbell » Mon Apr 22, 2013 11:00 am
robin wrote:Not that I ever sell cars I would expect to leave it as is (i.e. rebuild with your block if required) is probably best value in long run.
However the block is potentially the source of a tiny coolant leak, according our tame specialist technicians, in which case the question will be can that be repaired or not. If not, it's a new block...
Highly unlikely you have a coolant leak near the rear of the engine -
are you actually losing coolant?
ie having to top up the header?
Post by campbell » Tue Apr 23, 2013 11:27 pm
Going by Murray Lotus findings, Simon, based on pressure testing results.
No practical impact so far but like any leak I only expect it to get worse ;-)
pete
Vexatious Litigant
Post by pete » Wed Apr 24, 2013 1:00 am
Campbell build me on too. Considering the amount of rough love mine's had it's only a matter of miles....
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Post by Sanjøy » Wed Apr 24, 2013 8:11 am
Facility is all yours Campbell.
S
Post by robin » Wed Apr 24, 2013 8:38 am
Pete, you won't need a new block - probably - so you can just recycle your block when the time comes :-)
Post by campbell » Wed Apr 24, 2013 11:24 am
Sanjoy wrote:Facility is all yours Campbell.
S
Wow, thank you!
Craig may be masterminding this for me at Murray, but who knows...we are a long way off!
steve_weegie
Post by steve_weegie » Wed Apr 24, 2013 12:01 pm
Campbell, if I were doing this (again) I'd absolutely build an engine to a spec dictated by a budget I had planned in advance. :lol:
New liners and pistons / rings are a given for me though. New clutch and cover too, all fully balanced + balanced flywheel. :thumbsup
Post by campbell » Wed Apr 24, 2013 12:58 pm
Interesting points, Steve, ta.
Clutch still feels like new it OTOH I guess it doesn't owe me anything!
steve_weegie
Post by steve_weegie » Wed Apr 24, 2013 1:17 pm
I agree, but in hindsight, my experience is that I really wish I could have spent a little more and done a proper job. Nothing worse than after 10k miles on your new engine, you need to pull the gearbox off & fit a clutch, or in my case wish I'd used new liners.
An AP clutch isn't too expensive either & balancing it along with the flywheel will give you a smoother drive :)
Also, dont skimp on gaskets... I know from bitter experience that head gasket aside, all the other gaskets you'll change along the way should be as good as you can buy. Life really is too short for leaking crank and cam seals on a relatively fresh engine.
KingK_series
Post by KingK_series » Wed Apr 24, 2013 1:35 pm
S
what does that mean????
Are you building a new engine for Campbell?
KingK_series
Post by KingK_series » Wed Apr 24, 2013 1:37 pm
steve_weegie wrote:I agree, but in hindsight, my experience is that I really wish I could have spent a little more and done a proper job. Nothing worse than after 10k miles on your new engine, you need to pull the gearbox off & fit a clutch, or in my case wish I'd used new liners.
AP clutch is just a 'selected' Borg and Beck ie Rover OEM item
don't think its much better - except for a wider friction plate.
if you change a pressed steel clutche 10k down the road - you throw away all your money and effort in the balancing...
just one reason to dislike pressed steel clutches..!!!
KingK_series
Post by KingK_series » Wed Apr 24, 2013 1:42 pm
campbell wrote:Going by Murray Lotus findings, Simon, based on pressure testing results.
hmmmmmmm
forgive me.... deep skepticism keeping in...
1/ how did you fist hear about this 'coolant leak'? did the garage show you, or did you spot something?
2/ if you spotted something? - what did you spot?
3/ pressure testing a head is a recognised process, pressure testing an engine in situ can only tell you aboput the whole coolant circuit? - are you sure your radiator is not leaking?
- I'd believe that any day, coolant leaks from the rear of the engine - never seen it, could not possibly imagine how that would happen - feel that the possibility that that has happened is infinitesimally small .
beware ALL garages.......
Post by Sanjøy » Wed Apr 24, 2013 1:52 pm
S
Yup. Bullet proof 200 ponies. Just put dinosaur juice in it.
graeme
Post by graeme » Wed Apr 24, 2013 2:00 pm
Need to get mine booked in with you for your twin-charger conversion Sanjoy. I hear good things about it. How busy are you?
