SE Help? Glue/resin/plastic repair
shooomer
Post by shooomer » Tue Feb 18, 2014 5:05 pm
I have a water valve with a hairline crack and replacement is on 6 week back order. Anyone any advice if I can use something for temporary repair? It's made of Acetal?
Thanks
Re: SE Help? Glue/resin/plastic repair
Post by tut » Tue Feb 18, 2014 5:42 pm
Always the same, gaffa tape............ :D
Better advice than mine should be available Paul, but as I have some in I would try Metalset as a starter.
Post by woody » Tue Feb 18, 2014 6:20 pm
Can you post up a photo Paul?
Post by rossybee » Tue Feb 18, 2014 6:24 pm
For temporary use, I'd go with Denso Tape every time Paul :thumbsup
shooomer
Post by shooomer » Tue Feb 18, 2014 10:14 pm
It was tough to photograph on my phone. I was thinking I could fill the whole circular cavity with some sort of resin? It's only at mains water pressure
thanks :thumbsup
Scottish Scrutineer
Post by Scottish Scrutineer » Wed Feb 19, 2014 8:34 am
Epoxy resin should do. Just make sure it is clean, dry and keyed before you cover it
Renny
Renny Thomson
MSA Scrutineer
Elise S2 (2002)
hiscot
Post by hiscot » Wed Feb 19, 2014 9:19 am
I would cut a metal or plastic disc same circumference as the out side and bond it on with stickaflex
the stickaflex should seal the hole and the disc would spread the load and seal at the same time
mains pressure from a tiny hole is quite a lot
bob
Post by Rich H » Wed Feb 19, 2014 1:46 pm
If it's for drinking water I'd be very carful about what you use...
flyingscot68
Post by flyingscot68 » Wed Feb 19, 2014 2:17 pm
I'd just mix up some araldite then pour it in to that handy little hollow there and leave it to set.
Would be worth trying to put a jubilee clip on to help hold it all together, hard to tell from the picture if that's doable though.
Post by Scotty C » Wed Feb 19, 2014 3:42 pm
send stu an e-mail and he will make you one in Stainless :thumbsup
vet111s
Post by vet111s » Wed Feb 19, 2014 6:44 pm
flyingscot68 wrote:I'd just mix up some araldite then pour it in to that handy little hollow there and leave it to set.
:withstupid although I have no qualification to back this up
pete
Vexatious Litigant
Post by pete » Wed Feb 19, 2014 7:04 pm
Rich H wrote:If it's for drinking water I'd be very carful about what you use...
Depends who is drinking it.
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
