UBD2 reader.
UBD2 reader.
Post by tut » Wed May 14, 2014 10:08 pm
I have had the MIL light on all weekend, so if anyone has a reader I would be greatful if they could bring it along to KH tomorrow.
neil
Re: UBD2 reader.
Post by neil » Wed May 14, 2014 10:13 pm
I'll have mine with me tut
Exige V6
Re: UBD2 reader.
Post by tut » Wed May 14, 2014 10:34 pm
Cheers Neil.
Leaving at 0900 for MMC as Craig is going to give the car a once over before Spazz.
neil
Re: UBD2 reader.
Post by neil » Wed May 14, 2014 10:34 pm
I'm sure Craig will also have reader!
Exige V6
highlander
Re: UBD2 reader.
Post by highlander » Wed May 14, 2014 10:57 pm
MIL light came on when I got stuck in Edinburgh traffic picking car up from MMC.....running fine but got a heads up from Mike as to what the likely cause would be and checked/shown at Inveraray the other week.I bought the OBD2 reader from EBay and cancelled the "fault" and it hasn't reared it's annoying head again/yet.Haven't had time for the mod yet but it's a lambda probe issue for me.....2nd probe not seeing a big enough difference in the readings between the 2 probes....before and after the cat......answer is to mount the 2nd probe on a spacer so it's effectively out of the gas stream and gets a significantly differant reading.Still waiting for the spacer to arrive :cry:
Should be 2 minute job to clear the MIL light.
Re: UBD2 reader.
Post by robin » Thu May 15, 2014 5:34 am
Tut, I am surprised the MIL is even connected! Hopefully if they connected the MIL they also connected the OBD2 pins to the ECU, otherwise I am not sure where you'll connect the OBD2 reader?
Re: UBD2 reader.
Post by tut » Thu May 15, 2014 9:09 am
Good point Robin, will see if I can get a reply from Keith before I leave. He does not have a CAT on the car, but this was the first time that it had come on and I have already done 2,000 miles.
r10crw
Re: UBD2 reader.
Post by r10crw » Fri May 16, 2014 11:50 am
I have one but I thought you said its on a kpro, just plug this in? Ive it setup on my laptop so just come round.
Hairdresser at heart.
neil
Re: UBD2 reader.
Post by neil » Fri May 16, 2014 11:57 am
My reader worked on it last night. The code was P0106 - Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance. How did it go after we reset it tut? I didn't see you there at the end of the night.
Exige V6
Re: UBD2 reader.
Post by tut » Fri May 16, 2014 3:04 pm
It's a K100 Craig so none accessible.
I am keeping the K-Pro that you took off the old car.
Re: UBD2 reader.
Post by tut » Fri May 16, 2014 3:07 pm
It stayed off for a while Neil then came back on. Will pass the code over to Scuffers.
Had to leave at 1900 so was only on for an hour.
Re: UBD2 reader.
Post by meatball » Fri May 16, 2014 7:47 pm
tut wrote:It stayed off for a while Neil then came back on. Will pass the code over to Scuffers.
Wondered where you went to!
Re: UBD2 reader.
Post by tut » Fri May 16, 2014 7:55 pm
Looked for you Campbell but you must have been pimping with someone else.
Re: UBD2 reader.
Post by meatball » Fri May 16, 2014 8:52 pm
tut wrote:Looked for you Campbell but you must have been pimping with someone else.
Such a tart!
