Basically it's everything in this kit
http://a1barstuff.co.uk/keg-beer-dispense-kits10
I was hoping to use it but the trial run this weekend confirmed that the current set up needs new lines (£0.40p / m) and some new seals (£10 max) and a proper clean out................and i can't be arsed with this on top of everything everything else going on at work and in the house.
The system has Bass logos on it so i'm guessing it originally started life in a Bass pub somewhere. I've had it running long enough to establish that it leaks a bit (see new lines and seals above) and that it hadn't been cleaned in fooking ages (see needing a proper clean out above). Sadly this was only discovered a few hours before i was due to have a housewarming and after i'd just opened an 88 pint keg of Budweiser
So you can have the keg too, it cost £144 alone and was delivered a few days ago. I'm going to assume that i've ruined it now but it might be worth something on an exchange basis if nothing else.
Appreciate it's not the normal thing for sale on here but thought it might be of interest to someone
