Suspension Bushes
thesurfbus
Suspension Bushes
Post by thesurfbus » Thu Nov 27, 2014 9:25 am
I know this has been covered before, but what suspension bushes for my S1 Elise?
Predominantly a road car, had it up Forrestburn a few times and it will get to Knockhill at some point, should I just go for Lotus OEM bushes, or should I consider Poly or Ertacetal, although not heard much about Ertacetal any views?
Also should I get the wishbones powdercoated or POR15?
Doug
Lotus Elise 220 S
Re: Suspension Bushes
Post by tut » Thu Nov 27, 2014 9:35 am
I think the advice Doug would be stick with the Lotus rubber bushes if it is mainly road work. More compliant and last longer than the synthetic ones, which are deliberately stiffer for the track.
As for coatings I think it is pretty much 50/50, I have always gone for powder coating, but POR15 could be better lasting and you can apply it yourself.
Post by BiggestNizzy » Thu Nov 27, 2014 2:25 pm
I did my fronts in 'Armourcote Beetleback'
Post by woody » Thu Nov 27, 2014 3:13 pm
I fitted OEM type bushes from seriously Lotus to the front of the 160 earlier in the year, the rears will be getting the same soon. One of the best changes I've made to the car over the years.
thesurfbus
Post by thesurfbus » Fri Nov 28, 2014 8:48 am
Thanks for the responses, looks like I will get the OEM style Bushes from Seriously Lotus.
Still looking at paint/powdercoat options. My TVR chassis/wishbones were powdercoated and with just over 1000miles on the car, it hasn't lasted well. I already have POR15.
Doug
Lotus Elise 220 S
thesurfbus
Post by thesurfbus » Wed Dec 03, 2014 9:23 am
Do I need to invest in the bush fitting tool, or will the normal socket bodge work?
Lotus Elise 220 S
Post by woody » Wed Dec 03, 2014 10:07 am
thesurfbus wrote:Do I need to invest in the bush fitting tool, or will the normal socket bodge work?
Sockets & a G clamp, later swapped for threaded bar, worked well for me.
thesurfbus
Post by thesurfbus » Thu Dec 04, 2014 8:58 am
Lotus Elise 220 S
AJT
Post by AJT » Thu Dec 04, 2014 9:21 am
I have the Elise parts tool if you would like to borrow it.
Alan
S2 111S
Post by Stephen » Thu Dec 04, 2014 4:12 pm
Doug
I had the wishbones on my last car acid dipped and zinc plated at a place in Newhouse. I then did them with POR15 for good measure.
The dipping and plating was only £100.
I'm going to do the same for the 160 too.
thesurfbus
Post by thesurfbus » Sat Dec 06, 2014 9:01 pm
Lotus Elise 220 S
